hey guys my father can't get his '92 bird to start he's changed spark plugs, spark plug wires, distributor cap, rotor, and ECM. now we are thinking bout changing the starter solenoid or thermo switch( his ideal) and i was just thinkin maybe one of you can help plz any thing would be great!
Re: plz help now!!! problems! ASAp
what does it do when you turn the key anything>?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
need more details. is it getting fuel? hows the timing? How does the compression look? does it turn over and just not start?
http://members.cardomain.com/jm9301 It runs once more. Parked for winter. |
Did you check the ignition module before changing all the other things? Sounds like you were looking to get spark.
well you can hear the starter and it sounds like its gonna crank but it never does.
k they're telling us that the coil is good but we are not get any spark past the coil and just changed starter 20 min. ago! had discount check start ignition module and they said it's good any help?
You have a distributor or a coil pack? And is the engine cranking slowly, or just clicking, or engaging and not turning over the engine. Possible Battery problem, maybe a battery wire. You've said you changed all the other ingition parts. rare possibility that the timing chain broke, or it jumped and threw the timing out of whack. But what are the exact symptoms and details. I am not there to witness it, i'd like to give you some better info rather than speculations. let us know more, i am sure from what i have read on this forum so far that we have the answer amongst us.
I would check and make sure your timming isn't off after you've replaced all that you have. Did you put the plugs in the correct firing order (this seems to be a problem more than it should be)? If it isn't cranking over I would then check out the battery as tamax said. If thats alright, the starter solenoid could be the issue.
Yeah more details man, I know every part of starting a 3rd gen firebird, because i've replaced every part there is that's involved in it. What EXACTLY happens when you turn they key, what sounds do you hear, what works, what doesn't?
k something i should have already said which i haven't (cuz i'm a dumb ass) it's a 3.1l v6 we've checked the timing chain and it seemed ok or that's what the told me it turns over and cranks the entire time you hold the key over and it sounds like a normal crank exept for the part were the engine dosen't come to life and so far the new parts list in the last 5-days is spark plugs, wires(2 sets have been switched in and out the first set was bad and yes we have it in the right firing order after 6 tries), dis. cap, dis. rotor, starter, ecm, and the coil is good and thats what i'm sure bout one or two other things might had been changed but i'm not sure and if anything major was changed i'd have it in here. but its just a pain in the ass it just cranks and makes that ren-ren-ren sound but won't come to life as i like to put it. if that dosen't help let me know exactly what you need and i'll get you the answer! i appreciate all your help thank you all very much!
The solenoid was replaced with the starter, correct? Sounds like everything is working right, is it getting any fuel?
k late breaking news getting spark to the coil but thats as far as it goes does'nt get to the dist. the conection going from the coil to the dist checks out fine and now were lost plz help!!!
Re: Re: plz help now!!! problems! ASAp
k so were now using a 90 lumina for parts (3.1l V6)
cuz it ran up until the head gasket blew a couple of weeks ago. so we took the coil from that and put it on and it still isn't working and as for tech. automan's Q yes the entire starter sys. was changed. and as for JM93's Q yes it is getting fuel and as for everybody's timingchain Q the timing chain is perfect.And Philo yes we are getting all 12v to the coil. So we are still stumped. unless maybe two months ago the tranny mount got busted and it might had messed up the nutreal safety switch... could that be the problem??? |
if it was the safety switch the engine wouldn't turn over at all. This is a hard one, if all the electric portions are fine and it's getting fuel, then the only thing left would be timing is off, unless you have major internal damage and there's no reason for that right?
