Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 11-07-2004, 07:12 PM
el cheesmo el cheesmo is offline
Where is...88 Pulsar anti-deiseling solenoid
I've got a Chilton's manual that kind of shows where it is, but not really.
Can anyone direct or show where this is?
Cheers
el Cheesmo
edit/
Oh yeah, it is the 1.6 engine
Old 11-18-2004, 12:09 AM
miverson332's Avatar
miverson332 miverson332 is offline
Re: Where is...88 Pulsar anti-deiseling solenoid
If you look under the Fuel Chapter Section 5-7 it is on the left hand side of your Carburetor if you are facing it. It looks like a giant Bolt with a wire harness comming out the end holding two wires inside. You may not have this if you have an 88 Pulsar E16i. I have an 88 Pulsar E16i, and it does not have this. If you do have the E16i, the only thing similar to this is the Throttle Valve switch located on page 5-25. It is in the same area the anti deisel would be. Let me know if this helps.
