Old 02-22-2002, 11:29 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Unhappy Melted Fuse
Hey, I got a Question. I was wondering why my in-line fuse would have melted. I am running a 100x2 RMS Amp on a 10 gauge wire. I have a 30 amp in line fuse that melted. Why did this happen? How Do I stop this from happening again?
Thanks!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 02-22-2002, 11:38 PM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
the fuse itself has melted right? check the amp draw on the amp (sounds funny) make sure that is below 30 amps/. if not run a higher rated fuse.. i think u can get glass fuses as slow blow too.
Old 02-23-2002, 01:37 AM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
I wouldnt suggest using anything smaller then an 8 guage wire for power wire... even for small amps. Because the distance makes the amp work harder ~ so tiny wire, long distance... means the amp works harder then it needs to. I would suggest taking a look at your amp fuse(s) and see what they are... but I would also suggest you look into an 8 guage kit.
AF's Official Asshole
RIP AUNIE
Old 02-23-2002, 08:29 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you also may wanna check if your power wire and ground have came into contact with each other, or the power into metal, that would short the system too.
i agree with what ^^^ said, change the wire to at least 8awg, or even just go 4into distro blocks so its easier for the amp to get constant power. plus if you ever upgrade the thicker wire is already there.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-25-2002, 08:48 AM
Tireburner's Avatar
Tireburner Tireburner is offline
Your current draw on a 100 x 2 amp far exceeds 30 amps. On top of that the wire run (as previously suggested) is far too long to be supported by the gauge wire you are using.
Personally I feel 8 ga. is still too small. I would run 4 ga. and fuse it at the battery with an 80 amp fuse.
Why isn't common courtesy more common?
Melted Fuse box piyush1 Beetle - New/New Beetle Convertible 0 10-15-2010 06:55 AM
melted fuse for radiator fan 99 Beetle wahu Beetle - New/New Beetle Convertible 3 01-08-2006 09:42 PM
88 camry with melted fuse karikari Camry/Camry Hybrid/Vista 1 07-09-2005 04:13 PM
Melting Fuse Box For Auxillary Fan Causes Overheat mayoslc 5 Series 3 08-01-2004 12:31 PM
Melting Fuse Box Problem Creates Losing Coolant mayoslc 5 Series 10 07-18-2004 07:52 PM
