Old 11-07-2004, 05:56 PM
blancoloco412 blancoloco412 is offline
converting to ob1
ok have b17 with b16 obd0 ecu i was wondering if i get that harness that will convert to obd1 to allow b17 ecu in it. i read all i would have to do is run the o2 sensors. would this help out w/emmisions. is it really that simple what changes would i have to do in the wiring. oh yea i forgot i would to change the dizzy would just clip into harness or would i have to modify to get that in to.
Old 11-08-2004, 01:50 AM
anthony90si anthony90si is offline
Re: converting to ob1
i believe the plugs are different for the ecu and dizzy and o2 sensor
Old 11-08-2004, 08:25 AM
93/01alaLUDE 93/01alaLUDE is offline
make sure you get the obdo to obd1 conversion harness if getting it somewhere like ebay read the fine print b/c most conversion harnesses are obd2 to obd1 May be a lil more expensive...$5-10 but get the one w/ colored wires and not all one color. This will help w/ your sensors and such. You might have to splice wires to put them on...if you dont have experience w/ this then get someone that does to do it. Will help if you have your ecu wiring guide..should be found in a mechanic book for whatever year your car is
