Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 11-07-2004, 05:40 PM
epep epep is offline
Angry 90 GT problem...
i recently got two problems on my 90 GT manual...one is my idle speed, whenever i have a short period of time of stopping of my car, i.e. runs forward then stops then backward or stop and go in traffic, once the rpm hits the idle(750rpm), it would occasionally drop to abnormal idle(400-500rpm), i even got it dropped to 200rpm once. i have no idea why this happens, anyone knows??? (i got a TRD air filter on it)
the second problem...when i gas on my car(at any speed, any rpm), no matter i am gonna brake on it or not, AT THE MOMENT when i release the gas(gonna cruise or brake) my car stalls/jerks once or twice, then it smooths out, i notice the stall is coming from my left front, so it's from the shocks, wheel alignment, gearbox, clutch or the engine???
thanks if anyone could help...
Old 11-07-2004, 05:55 PM
Lan.Evo.VIII's Avatar
Lan.Evo.VIII Lan.Evo.VIII is offline
Send a message via AIM to Lan.Evo.VIII Send a message via Yahoo to Lan.Evo.VIII
Re: 90 GT problem...
It is happening to me too with the first problem you are having, but today mine stalled on me. I had to restart it twice.
I hate it .
Old 11-08-2004, 11:58 AM
91 Celica St 91 Celica St is offline
AF - Advisor
does it erk in all gears or just 1st and second...and whne ur cars idel goes low do you have your headlights on or alot of electronical things?
Old 11-08-2004, 07:10 PM
Re: Re: 90 GT problem...
for the idle problem, yes i am in 1st or 2nd when i am in that short period of time. usually happens when i park my car (like in that few seconds when i stop and shift to reverse), and slow traffic, stop and pick up frequently. it happens even with no electronics on.
Old 11-09-2004, 10:56 AM
AF - Advisor
hmmm does it do it in 3rd or 4th or 5th? or just 1st and 2cond
Old 11-09-2004, 01:03 PM
usually at that kinda speed, most of the time i am in 1st or 2nd, rarely in 3rd or 4th...
Old 11-09-2004, 02:01 PM
AF - Advisor
its eather u suck at driving, or your clutch is shitty.... when you shift does the rpms stay the same for a second then go down or do they go up for a second athen go down?
Old 11-09-2004, 04:51 PM
i completely disengage the clutch when shifting, my clutch is working good. the rpm goes down to idle when disengage the clutch, then it does stay at idle for maybe 10th of second, then goes down to 4-500rpm or even lower before i engage the clutch again. and the rpm won't go up and down, it just does this...rpm to idle, stay for a 10th of second, then goes down to 4-500 or even 200 once, then back to normal 750. the whole process happens before i engage the clutch.
by the way, the idle even goes down to abnormal sometimes when i am in neutural with engaged clutch. so i don't think it's the clutch.
Old 11-09-2004, 04:53 PM
btw, no one got any idea of my second problem??
Old 11-10-2004, 12:52 AM
shsaint shsaint is offline
shit happens to me...
only in first gear ...when i punch it and quickly release the gas it feels like the car jerks....front and back
when i'm in traffic-on the freeway...on a slope up hill( EVERYBODY hates it) mine jerks back and forth
regardless how good i smooth the clutch
or i gotta put a little bit more gas into it to smooth it out
anyway, the whole suspension feels loose ONLY on first gear
Old 11-10-2004, 10:41 AM
AF - Advisor
shsaint...its supposed to do that, you have tourqe in ur first gear, itll do that to any manual...
Old 11-10-2004, 01:03 PM
shsaint....prolly you didn't match the rpm when you shift, try bring it up to 4K or more at 1st when shift up and heel and toe when shift down, then you will see how amazing the smoothness of shifting...
seems my two problems are leftover in this thread now...
Old 11-10-2004, 01:44 PM
AF - Advisor
haha sry...i dunno ud have to take a look at it to find out, im thinkin tranney and most likely clutch problem
Old 11-29-2004, 09:04 PM
tbg tbg is offline
Send a message via MSN to tbg
Similar thing happened to my car (91 gt) just before I bought it... A friend had it stored for just under a year, when he brought it out it wouldn't hold a proper idle... kept dying on him, forcing us to get a boost. Turns out a new battery fixed it, although even then, it doesn't hold a charge in cold weather (and I live in Canada D= )... I don't know what to suggest other than have someone check the charge on your battery.
Hope this helps.
Old 12-01-2004, 01:40 PM
Johnsmatrix Johnsmatrix is offline
I fixed that problem on my car with a new cap/rotor/plug wires.
