Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-07-2004, 05:39 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
uh oh, bolt broken...
one of the heads on the four turbo bolts is missing( it was like that when i bought it...)
do you guys think that, that could be a sorce of why the owner before me said "...ya the turbo is kind of weak, one day i took it in for an oil change and it felt weaker ever since..."
is there also any ideas how to get it out?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-07-2004, 05:52 PM
joemathews's Avatar
joemathews joemathews is offline
Re: uh oh, bolt broken...
Well, you probably have an exhaust leak at the manifold-to-turbo gasket. I can almost assure you that gasket is bad if you've been driving it like that for a while--and exhaust leaks before the turbo are NOT the friend of performance . I'm not sure how you would go about fixing it, but surely one of these guys will come along with a solution
1996 Eagle Talon
Old 11-07-2004, 05:59 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
use an easy out. id also take off the turbo and replace the manifold to turbo gasket. might be a good excuse to do a 14b too
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-07-2004, 07:41 PM
97_3clipse's Avatar
can u put a 14b on a stock car?
Old 11-07-2004, 08:11 PM
97_3clipse's Avatar
bone stock except for all the free mods and front and rear sturt bars
Old 11-07-2004, 10:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
Take out the other 3 bolts. 99.99% of the time that broken bolt is loose in there And for what its worth I ran with 3 turbo bolts for like 2 years, making some of my best numbers at the time. Not that 4 bolts wouldnt be better, but dont expect it to cure much.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-11-2004, 01:51 PM
riff22 riff22 is offline
ez-out if it works it will be hard getting it out of that cast iron. if that dont work maybe drill it out and re-thread it?
