1995 truck full size
can someone tell me where the fuel pump reset switch is please?
Re: 1995 truck full size
I'm not sure, but can suggest checking owner's manual if you have one, or going on www.allpar.com.
fuel problem
alpar sit no help and cant find owners manual/need more help!
there are no fuel pump reset switchs on dodge trucks to my knowledge. None listed in my truck manual, or repair manual.
What problem are you having Hoscat? Have you checked the fuse for the fuel pump? Checked fuel pressure at throttle body /injectors? Fuel in tank? Need some more info about your problem.
I changed my fuel pump and I never heard of, nor saw, a fuel pump reset switch. It's not in the haynes manual either.
fuek pump problems
its my neighbors truck it has been sitting 3 mts. when you turn on key i can not hear pump come on and when i push the valve stem in on fuel rail with key on i just get small amount of gas out it does not spray out,i checked fuse that looks ok not blown,maybe its a bad pump.
