Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-07-2004, 03:20 PM
civicguy167's Avatar
civicguy167 civicguy167 is offline
Send a message via MSN to civicguy167
Shifting Problem
Alright, I was driving up a hill yesterday and was in 2nd then went to shift to 3rd and it wouldnt go into it. So i pulled over and found that it wouldnt go into 3rd or 4th at all. After messen around with it for awhile on the side of the road i could get it intop 3rd and 4th if i really pushed on it, but it would still slip out of 3rd on my way and get stuck in it also. I was told it could be the shift linkage or the clutch.
ANY IDEAS OF HOW I CAN FIX THIS PROBLEM?????
Old 11-07-2004, 04:32 PM
b18ls's Avatar
b18ls b18ls is offline
Banned
Re: Shifting Problem
Transmision. Chances are you need a new one. Just in case, you can check the shift linkage and see if somthing is jammed.
Old 11-07-2004, 05:38 PM
how would i check the shift linkage? The car has never had any problems since ive owned it and been well taken care of. Its got 118,000 miles on it and it seems like the tranny would last longer than that.
Old 11-07-2004, 10:20 PM
honda_luvr_2000 honda_luvr_2000 is offline
just get under the car and look at the linkage. u'll notice if there is sumthin there that shouldn't be. it just runs from ur shifter to ur tranny. it's not the clutch, cuz it went into other gears fine right? definantly the linkage or tranny. sorry to say, but most likely the tranny
