Old 11-07-2004, 03:12 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Throttle Body Coolant bypass
How do I do it?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-08-2004, 03:21 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Throttle Body Coolant bypass
i just figured my way through it, never bought one of those kits they sell:
drain your coolant
remove the intake tube from the throttle body
directly below the throttle body intake are two coolant hoses
i think they run from top to bottom between the pump and the TB. i just unhooked them and plugged one of the hoses across the two ports on the TB and the other on the two ports on the water pump. (so they are running side to side) i dont really remember too well so you might have to improvise something.
*Better power-to-weight ratio than a C6 corvette*
Old 11-08-2004, 03:49 PM
Dober89 Dober89 is offline
I never drained my coolant when I did mine.
Old 11-08-2004, 04:57 PM
So make the WP hose loop back to the water pump and the TB hose loop back to the TB, thats it?
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-08-2004, 06:14 PM
thats what i did...
Old 11-08-2004, 06:18 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
what's the point of that?
Old 11-08-2004, 06:24 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
you could pull both coolant hoses off the TB and join them? seems simpler.. and no you dont havta drain the coolant.. you'l just have a little bit leak out while your doin it is all..
an easy 3 or 4 horsepower..
1991 Camaro Z28
Old 11-08-2004, 09:27 PM
Re: Re: Throttle Body Coolant bypass
Thats all I did, just went out a found a 3/8" coupling and bought 2 hose clamps. I forget is that was the correct size but those were the only 3 things I had to buy and coolant will only drip out of the hoses for the most part when you point them down.
Old 11-09-2004, 12:57 AM
So is that a better way? and how much am i looking at for 3/8" coupling and 2 hose clamps/ is it any special coupling?
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-09-2004, 01:58 PM
DaMoNe6969's Avatar
no.. even a piece of copper pipe that will fit inside the two hoses to join them, than you can clamp it.. your lookin at about $2 dollars?
1991 Camaro Z28
Old 11-09-2004, 07:00 PM
i dont see why you need to buy the pipe. if you get it than you still have to plug the tubes that go into the throttle body. i recommend just using the factory hoses to loop the coolant passed the TB; take your 2 bucks and buy a job-well-done-soda...
Old 11-09-2004, 08:57 PM
So some people are saying to loop the water pump hose to the water pump and same with the throttle body; others say to basically delete the TB from the hoses and clamp them together as they would flow normally, just without the TB in there? First method sounds easier/cheaper while the 2nd method sorta sounds better. Any difference with either?
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-10-2004, 12:29 PM
i dont think there is any difference. the second way (if i understand it correctly; as in the way that the kit does it) is just using a piece of pipe and some hose instead of the factory hose. it also requires to plugs to go where the hoses went into the TB (if you ever want to go back to the original setup).
the only reason i did it the first way is cause i was doing an induction service and at the last second remembered about doing the bypass, so i didnt have any pipe or hose bought. did all the bypassing with the factory hose and it works fine...
Old 11-21-2004, 05:45 PM
Doesanyone have any pictures? How big are the hoses? I was gonan do it today but wasnt too sure what I was looking for...
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-21-2004, 08:02 PM
i might have some pictures of mine kicking around but its a 3rd gen TPI.
