Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 11-07-2004, 01:50 PM
vvs1de vvs1de is offline
Question starter on 89 corsica
I feel like an idiot, but where is the starter on the 4cyl corsica? How do I replace it< Thanks
Old 11-07-2004, 08:02 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
On the bottom of the engine. Dunno if its in front or back. Its a large round black/rusty cylinder thats probably completely covered with grease and oil. Take ou the two bolts taht hold it to the block, remove the wires from it and it drops out. Install the new one in reverse order.
Old 11-09-2004, 04:18 PM
dwalmop dwalmop is offline
Re: starter on 89 corsica
follow battery cable down to it
Old 01-07-2005, 08:42 AM
bcopeland bcopeland is offline
Its right in front below the exhaust pipe right behind the fans.
Old 01-07-2005, 05:43 PM
beuthling beuthling is offline
unplug battery before working on starter or anything first!
-How do you no it's the starter
code be coroded terminal
-symptoms
usually if my starter dosent work i give the wire a wiggle
Old 01-08-2005, 09:32 AM
That is sooooo right. Sometimes it is just a corroded battery terminal. I had many of those on our cars.
Old 01-08-2005, 02:12 PM
corsifreek corsifreek is offline
Send a message via AIM to corsifreek
or it could be the silonoid.. try to bypass it by connecting a screwdriver to both of the bolts on the top of the silonoid.
Old 01-08-2005, 11:44 PM
jsgold jsgold is offline
One thing to be wary of. It is possible that your starter has a "shim" between it and the engine, to properly space it, or, the replacement starter (if you DO replace it) may come with one that is needed. if you don't use it it can cause problems.
