Old 11-07-2004, 06:32 AM
camping camping is offline
Rear Quarter Window Leaks Air
2002 silverado extended cab 4-door. Window makes noise like air is coming in. This is only on drivers side,rear quarter window. Any ideas?
Old 11-07-2004, 09:03 PM
AaronIROCZ AaronIROCZ is offline
Mine is doing the same thing on the passenger side, I read on here a while back and the only thing you can do is replace it. But I am going to try some thin Foam weatherstrip and see what that does.
Old 11-07-2004, 09:29 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: Rear Quarter Window Leaks Air
yeah mine does the same....i looked at it, and the latch is loose where it connects to the column. i think im gonna have to take it to the dealer to get it fixed.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 11-08-2004, 06:29 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
Is it just me or do the latches on these windows not seem to click shut very hard. I think it should be a little stiffer to open these windows. Like, when you shut the windows, i would like to hear a nice "click" or something.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 11-08-2004, 06:54 AM
Where are you putting the foam weatherstriping? Let us know if that helps.
Old 11-08-2004, 01:38 PM
cesderek cesderek is offline
Re: Re: Rear Quarter Window Leaks Air
The dealership installed screws on the back side of the bracket to stiffen the latch. The latch does not "click", but it does make the latch close stronger. The screws go from behind the handle to the frame work of the window. I tried using weather stripping also, but made the window produce even more wind noise.
Old 11-08-2004, 08:35 PM
PigPen5150 PigPen5150 is offline
Send a message via AIM to PigPen5150
When I worked for Chevy we replaced the windows. Don't know if they have another fix now, but this was only 9 months ago.
Old 11-29-2004, 03:40 PM
isophase isophase is offline
Send a message via AIM to isophase Send a message via MSN to isophase Send a message via Yahoo to isophase
I had same issue with my 2000 Silverado.. Dealership told me to get a paste Silicon.. Apply a thick coat to the Rubbers (All Seals) let sit over night with Doors Open or Glass.. and in the morning wipe off excessive Silicon.. and it would make the Seals Expand to original Size (sealing air noise)
Old 11-29-2004, 05:19 PM
nineball481's Avatar
nineball481 nineball481 is offline
Did you try that, or are you going try it? Did it work? Thanks.
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 11-29-2004, 05:20 PM
Havent tryed it yet.. But definately going too.. My Rear Quarters have a lot of road noise .. ANNOYING!
Old 12-06-2004, 04:43 PM
xlseeor xlseeor is offline
Mine was doing the same thing, but on the passenger side. I bought an replacement window on e-bay and took the truck to a glass shop to have it put in. The guy there said there was no need for a new window. The old one had just popped loose in the frame. He snapped it back in place and didn't charge me anything for it. Problem solved. Anyone need a replacement for their right rear window??
Old 12-13-2004, 01:35 AM
'02 Z71 '02 Z71 is offline
when I bought my 2002 in Oct. they replaced the windows for me @ there expense @ the dealer. no problems since then!
Old 01-10-2005, 01:42 AM
{SBX}bigDaddy's Avatar
{SBX}bigDaddy {SBX}bigDaddy is offline
I had the same problem on both windows. I took it to the dealership and they replaced the latches under warranty. Never happened again.
I drive a 2000 silverado.
Old 01-10-2005, 05:44 PM
red00lght's Avatar
red00lght red00lght is offline
Well,
My 99 is way out of warranty and I never use the back side windows, so after trying about everything, I just used some spray adhesive to the weatherstripping and it holds the window shut with no noise. It seems to last pretty good...and I can easily open the window and get rid of the adhesive with goo-gone if necessary. Yes, you have to be pretty frustrated to glue your windows shut!!
Old 08-14-2005, 11:48 AM
Elmer_Fudd Elmer_Fudd is offline
Loose Rear Window
I have had the noise for a while, I took a good look at it today and the windows are getting ready to fall out. I think the leading edge is glued in and the adhesive is releasing. My warranty expired in June so I am going to raise h$@@ and see if they will fix it. take a good look at your window, if you close the door and see the front edge pop out, yours are loose too don’t push out on them from the inside you will only make it worse.
