Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-07-2004, 05:30 AM
rksmotorsports's Avatar
rksmotorsports rksmotorsports is offline
95 4X4 Rodeo Oil Pan Gasket
I need to do the oilpan gasket on my wife's Rodeo. How much of a headache am I looking at?
I've read that I'll need to drop some suspension components to access it. Is this true? I'm not used to working on foreign cars. (I drive/work on my 84 Dodge Ramcharger and my 84 C4 'Vette.)
Any advice will be appreciated.
I want to thank you folks on this board for the info re:"low oil pressure" and the oil pick-up screen. That's another question I had.
One other question. The top end is noisy as hell when running. A friend of mine says it's the injectors. Does anyone else experience this? (I've got 'Crossfire' injection on the 'vette and the sound of those 2 injectors firing does sound similar.)
Thanks all.
Old 11-07-2004, 09:00 AM
mwt mwt is offline
As far as the oil pan goes. I was quoted $600.00 for it and the rear main seal on mine by a dealer.
The noisy top end is probably the lifters and has been covered a lot on these forums. Mine was pretty noisy when I got it at 53K and I started using Mobil 1 synthetic and it was really dirty for the first few changes. It is a lot queiter now than when I bought it. Also a lot of people have used seafoam to clean with.
There are some threads about changing the lifters on this board that may help you out. I assume it is the 3.2 engine.
Mike
Old 11-07-2004, 09:36 AM
rodeo02 rodeo02 is offline
Pretty sure either the motor has to be lifted, or stuff moved out of the way to get the upper oil pan off (big aluminum skirt/pan). The little stamped steel lower pan is a piece of cake. IIRC the aluminum pan is sealed with RTV from the factory, but an AM gasket is avail.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
