Old 11-07-2004, 04:42 AM
MitsuPride3KGT MitsuPride3KGT is offline
Abs?
How do i find out if my car has abs or not? what is abs? i kno its braking system... antilock braking system.. how do i find if i have it or not much appreciated
Old 11-07-2004, 07:35 AM
Boosted1 Boosted1 is offline
Well, the obvious way is to get going a decent clip and come onto the brakes. If you don't have it, the tires will likely lock up and squeal. If you do, you will probably feel a rapid pulsation in the brake pedal, which is the ABS system working. If you do this, make sure it's on an empty road.
Old 11-07-2004, 12:27 PM
Re: Abs?
what do you mean decent clip?
Old 11-07-2004, 12:43 PM
Highway speeds.
Old 11-07-2004, 01:17 PM
Technical_Automan Technical_Automan is offline
Banned
If you have abs when you turn the key to the on position an indicator light will come on that says ABS in the dash. It will go out after a few seconds being that it comes on only as a bulb check. If you don't see this light then you don't have ABS, or the bulb is blown. If you're going to try what boosted said, wait until the ground is wet so you don't risk damaging something or wearing your tires excessively, but his idea would work too.
Old 11-07-2004, 03:02 PM
Re: Abs?
where would the ab light be shown at? what corner or right or left of my speedometer
Old 11-07-2004, 08:59 PM
Igovert500's Avatar
blue + red light magnet
Re: Abs?
It's in the FAQ
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-07-2004, 09:48 PM
StealthModifier StealthModifier is offline
Re: Abs?
Also check in ur manual, it has a picture that shows the shocks and has a wire coming down it to the brakes, if u dont have that wire in the pic, then u dont have abs
Old 11-08-2004, 12:47 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Abs?
The simplest way would be to remove the lid from the under hood fuse panel and see if you have an ABS fusiblelink(basically a large fuse) in there. If so then you most likely have abs. If not then you dont.
Old 11-08-2004, 09:39 AM
osok_deadeye_21 osok_deadeye_21 is offline
ok if my car doesnt have abs what will happen when i drive in the snow? i mean the car that i had before this was a ford explorer i mean it way different in the snow.
Old 11-08-2004, 11:13 AM
Banned
Re: Abs?
Well if you slide, you'll have to pump the brakes to stop sooner...that's all that ABS does is pump the brakes for you basically, except it can do it up to 24 times a second whereas you may be able to do it once per second. The only purpose of ABS is to control wheel slip when the brakes are applied, without it you have to do it yourself.
Old 11-08-2004, 11:15 AM
ok anyone in these forums have a 3000gt without abs and drive in the snow?
Old 11-08-2004, 11:35 AM
Stealthee's Avatar
Re: Abs?
My Stealth doesnt have abs and I have driven in the snow two years now. I havent had one issue. You just have to learn your limits.
Old 11-08-2004, 12:02 PM
what are the limits? besides speeding and driving reckless.
Old 11-08-2004, 12:05 PM
Stealthee's Avatar
Re: Abs?
Thats just it, everyones limits differ. I have driven in winter for 8 years now so I can pretty much handle my own. One winter I was drivng a 86 Mustang and had no issues making it anywhere. I stopped and helped several FWD people who couldnt get anywhere because they didnt know how to drive in the snow. Its all in throttle control.
