Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-07-2004, 01:07 AM
IWITR IWITR is offline
Question better gas better for car?
what gas company is good? and what gas number 87 89 91 (i think it goes like this) cars for LS, GS, GS-R??
my friend drives 240 and the only gas station he goes is chevron and puts 91. Anther friend drives LS and same thing chevron. Also does chevron gas clean the engine?? He said that chevron is the best gas. ture?? or false?
so......91 gas is better?
Old 11-07-2004, 02:39 AM
p0wered_by_acura's Avatar
p0wered_by_acura p0wered_by_acura is offline
Re: better gas better for car?
Yeah supposedly chevron cleans your engine...well the higher gas u use...the more likely ur engine lasts longer....76 also has good gas...i heard arco is known to put water in their gas to fill it up
Old 11-07-2004, 03:03 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
citgo is crap too. stay away from those stations, you'll car will run like ass.
Old 11-07-2004, 11:44 AM
thanx guys
Old 11-07-2004, 11:50 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
just avoid shitgo gas. Run what ever the lowest octane your car reccomnds unless you have altered the cams ECU added F/I or changed comp ratio.
Old 11-07-2004, 09:19 PM
Igovert500's Avatar
blue + red light magnet
Don't go higher octane unless you need it...there is no need, and it can actually cause your car to run worse(performance wise). The reason some cars need 91+ octane is because of compression or forced induction...they need it to starve off early combustion...aka knock, which screws up your pistons...turbo cars, etc, need higher octane fuel...if your car doesn't require it, don't use it. It's a waste of money and uselessly, prevents early combustion which isn't a problem in your car. If you don't have a turbo, supercharger, or nitrous, and your car didn't come from the factory requiring 91 octane...then stick to whatever is recommended. Essentially, if you car runs on 87, putting 91 in will not help...and may actually decrease performance.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-07-2004, 09:24 PM
thanx again guys
Old 11-10-2004, 09:03 PM
Fuxwitus 1st Fuxwitus 1st is offline
best bet is to go with Sunoco 93 ultra. i promise youll notice the difference. also remeber every time you switch different octanes of gas you should always reset your ECU. otherwise your car wont respond correctly to the good stuff
Old 11-10-2004, 09:11 PM
Igovert500's Avatar
Unless your Teg is turboed, you are wasting plenty of money on sunoco 93
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-11-2004, 04:36 AM
Re: Re: better gas better for car?
Personally i like sunoco 93 ultra because it makes my car perform better than anything else ive tried. It improves my torque and acceleration (and no i dont have turbo). Since i have a tornado fuel saver it doesnt seem like im wasting plenty money. get a fuel saver and try sunoco 93 ultra and judge it yourself..
Old 11-11-2004, 11:28 AM
Technical_Automan Technical_Automan is offline
Banned
Listen to Igovert500, he's the only one that knows what he's talking about in this thead so far lol. 93 makes ur engine last longer rofl, newb.
Old 11-11-2004, 12:01 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
listen to Igovert500, he knows what he's talking about. if ur car is an LS use 87 or 89 octane. gsr or type r's use 91 or better cuz of there higher compression ratio's. since LS B18A/B) have low compression pistons they dont need high octane fuel. if u noobs wanna waste ur money and buy the expensive 91 or better gas for ur cars then go ahead, throw ur money away!
www.MEDIUMRACING.com
Old 11-11-2004, 12:10 PM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
igovert500 and boosted k20... i love you guys!! seriously, almost no one seems to understand the concept of higher octane. i am glad at least you guys do. i have tried to explain this same thing several times on here and no one listens.
LS1 RX-7 Zoom Zoom
Old 11-11-2004, 12:17 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Im not running cams, turbo or nitrous, but I have advanced my timing about 3 degrees and I use 91 (89 at the least) to help prevent any knock.
Old 11-11-2004, 04:24 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Re: Re: better gas better for car?
Seeing as how you have a tornoado you have no clue.
