Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-06-2004, 11:49 PM
sky2k4's Avatar
sky2k4 sky2k4 is offline
Send a message via MSN to sky2k4 Send a message via Yahoo to sky2k4
defroster turning off after 3 minutes
yea it turnes off and then wont restart when the buttons pushed?
and of course it has frost on it,just dont make sense!!!
92 buick centry
Any i deas woulds be great!
ht8p://www.cardomain.com/memberpage/674104
thanks guys
come check out our site
Code:
http://www.coollinks2k4.com
and forum
Code:
http://coollinks2k4.com/phpcl2k4/
Old 11-24-2004, 01:25 PM
johncv johncv is offline
Did you get any information on this issue. I am having the same problem. When I first start it, it runs about 3 mins and then shuts off. When I try to turn it back on the light comes on then shuts off.
Old 12-02-2004, 12:21 AM
sky2k4's Avatar
any answers anyone 1992 buik
defroster turns off after about 3 minutes then when i click the button again it turns off in about 4 seconds?
its cold here in minn so if anyone has an idea Please let me know
Thanks in Advance
Old 12-26-2004, 11:22 AM
sky2k4's Avatar
Re: any answers anyone 1992 buik
Thanks in Advance
anyone???
Old 12-29-2004, 06:12 PM
Billski Billski is offline
Re: defroster turning off after 3 minutes
behind (and part of) the switch is a timer. some makes use a thermal timer. you switch it on and a bi-metal element is heated inside a module behind the switch. after 10 minutes or so, about the time your windows are mostly clear, it reaches a certain temp and the bi-metal element moves due to the differing expansion rates of the two metals, opening the circuit and shutting off the rear defroster grid. you can hit the button again but because the element is still heated, it won't stay on. it would take 10 min or so to cool off. who knows why these things suddenly decide to go into a short-cycle. bad batch of bi-metal elements or a vibration moved something around inside the switch. i've heard that some makes use a digital time. in any event, head over to your favorite auto parts store and see how much they'll nick you for the timer switch. replacing it should be a cinch.
Old 07-13-2005, 08:29 PM
sky2k4's Avatar
solved problem,lol
it was my fuses,had to buy resetiing fuses.
