Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-06-2004, 11:35 PM
kevinjski kevinjski is offline
TJ engine knock
I've got an 03 TJ 6cy with 14K miles. Just started hearing some engine knock 3rd through 5th gears at 2200+ RPMs. Most ofter under load such as while going up hill. Oil pressure guage appears normal and unchanged. Oil level is in range.
The only engine mods. have been a K&M air filter and installing a Banks Cat Back exaust.
I'm stumped. Any thoughts as to what is causing anf how to fix 'knock'?
Old 11-10-2004, 09:22 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: TJ engine knock
Is it a light pinging or a heavier knock?
How long has it been since you put in the K&N and exhaust?
Old 11-10-2004, 11:14 PM
Re: Re: TJ engine knock
Its a light ping. Within 2K of K&N and muffler. Since my original post I filled up with premium and knock is gone---so fare, Not sure I'm ready to say I got a bad tank.
What's your thoughts?
Thanks for taking the time to respond. Thanks man!!!!
Old 11-10-2004, 11:20 PM
JDPascal JDPascal is offline
Re: TJ engine knock
Sounds like a little detonation with the regular gas.
Check the timing and plugs for carbon buildup. Could also be combustion chamber deposits that "glow" and cause the pre-ignition.
JD
