Old 11-06-2004, 11:09 PM
mbdiggin mbdiggin is offline
ABS light & low coolant light on
On my 1993 buick park ave ultra my ABS & low coolant light stay on but there seems to be nothing wrong with either. Is there a sensor that might be bad?
Old 11-08-2004, 01:40 PM
pirho451 pirho451 is offline
If the ABS light is on, there is a problem somewhere in the system. You will need to take it in to a mechanic to diagnose the problem (unless you happen to have a GM Tech1 scanner handy).
The low coolant level problem is probably a bad sensor. The sensor is located on the back of the radiator, just below the upper radiator hose. It will have a wire that plugs into it. That's an easy fix.
