Old 11-06-2004, 08:36 PM
CrzyMR2T CrzyMR2T is offline
2g rear hatch leaks, or anywhere?
do any of you have problems with this? water getting through your hatch or whatever? i ve heard of problems with water getting through the hatch. any other seal problems? i also heard there was a recall on some seal.
mr2 club website m3
www.mr2oc.com
Old 11-06-2004, 08:44 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 2g rear hatch leaks, or anywhere?
i dont know about 2gs but on every 1g ive had the rear window leaks at the lower seal. i just pop the trim off seal the window edge with silicone and put the trim back.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-07-2004, 12:10 AM
george536's Avatar
george536 george536 is offline
on my car i have no leaks at all. But now i dont know. I got 14 holes back there.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
