Old 11-06-2004, 08:00 PM
IdahoGSX IdahoGSX is offline
1996 Power door locks intermitent
The power door lock on the driver's side locks and unlocks intermitently from the remote. Not sure what is causing the problem (actuator maybe). It may work for days then not. Any ideas?
Old 11-07-2004, 08:39 AM
mwt mwt is offline
THe concensus on the 96 to 99 is that the actuators are cheap. THey cost about $45.00 each and are a PITA to change. I have the same problem on my 99 and there have been a couple of threads here lately that stated the same problem you are having. Sometimes lubing them helps.
Mike
Old 11-07-2004, 05:13 PM
power lock
Has anyone tried using aftermarket actuators or is it best to use Ford replacement ones. I know the one's for my streetrod cost about $20.
Old 11-10-2004, 08:21 AM
wrsekul wrsekul is offline
Send a message via AIM to wrsekul Send a message via Yahoo to wrsekul
Re: 1999 Power door locks intermitent
I have a 1999 Taurus LX 4 and the drivers side back door will not unlock and lock! Is it hard to get to when lubbing them and where do you need to lube them, any tips!
[email protected]
Brandon, MS
Mike
Old 11-11-2004, 11:57 AM
TomV TomV is offline
I installed an after-market system on my 97 G and they seem to be holding up fine. I have not run into the mysterious locking problem with this system that I had, along with thousands of other owners, with the Merc Villager.
Old 11-11-2004, 06:43 PM
nomadamon nomadamon is offline
Re: 1996 Power door locks intermitent
wrsekul : have you thought of checking the wiring (if it is power)?
