Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 11-06-2004, 07:08 PM
rcdriskell rcdriskell is offline
engine overheats
My 2001 durango overheats when it is idling, and stays cool when it is moving. Also the heat doesn't work in the rear of the vehicle only the air works in the back. The control that the coolant runs into by the firewall leaks. could this have anything to do with it?
Old 11-06-2004, 08:45 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: engine overheats
Yes.
My Mopars
Old 11-07-2004, 03:43 PM
DurangoDave DurangoDave is offline
First step is to fix that leak, top off with coolant, and see if your problem is solved.
Dave
Old 11-25-2004, 02:06 PM
fastcompany166 fastcompany166 is offline
Absolutely have your radiator/condensor fan motor relay checked out. If it's bad, your fan is dead or intermittent while you are stopped, but could spin and provide some cooling effect while you are moving. Mine has been replaced twice over 60K+ miles.
