Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-06-2004, 06:11 PM
lobby7 lobby7 is offline
Question Buzzing noise when driving
My 98 Integra was just shipped cross county and now it is making a buzzing noise when driving (not when idling or revving the engine). The noise sounds like you are sitting inside a propeller plane when you are sitting in the car. It kicks in around 30mph, but isn't audible when driving slowly. It is also audible when decelerating until the car stops. Any idea what it is? What kind of damage could have been done loading/unloading it that would cause that noise?
Old 11-06-2004, 07:00 PM
pizzaman pizzaman is offline
Re: Buzzing noise when driving
I know 2nd gens have a problem with their speedo cables rattling. you might want to check you speedo cable out. If it is your cable lube it and it should shut it up for about three to six months.
Old 11-06-2004, 07:03 PM
DjMasaker's Avatar
DjMasaker DjMasaker is offline
It also could be the fender well plastic rubbing on the tire. Something may have gotten caught on the fender while shipping and pulled it a little....does it ever stop when turning?? if so, you can tell its the front, if not check the back and make sure there isn't anything rubbing.
Old 11-06-2004, 11:25 PM
p0wered_by_acura's Avatar
p0wered_by_acura p0wered_by_acura is offline
maybe some bees have formed a nest under your hood and thats where the buzzing noise is coming from
Old 11-06-2004, 11:34 PM
integralover's Avatar
integralover integralover is offline
is it inside the car or outside? if it is inside i would check the speedo cable. if outside it could be the wheel well lining or, damn i can't exactly remember the name for it but, the rotor bearings on one of the front tires. same thing happened in my sister's jetta. sounded like a damn plane too. at about 20 mph the damn noise would get more noticable. i thought it was just her tires but, apparently it was her bearings.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 11-07-2004, 07:44 PM
Update; and another question
I took it to a shop today and they said the front passenger bearing needs to be replaced. I have heard that you should always replace them in pairs. Is that true, or just an old husband's tale?
Old 11-08-2004, 09:35 PM
whitGSR07 whitGSR07 is offline
it's an old wife's tale
Old 11-09-2004, 12:35 AM
they are trying to get more money. they have nothing to do with each other. so replacing one will not hurt the other. nor does it mean the other will go soon. its more or less a precautionary measure. like saying just in case.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
