Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-06-2004, 04:17 PM
irontodd irontodd is offline
Send a message via AIM to irontodd
Technical: Engine Rebuild Question
I have been unfortunate enough to have to rebuild my 2.5L TJ Wrangler engine. I have the Haynes manual, but I am pretty sure there are some typos in the engine overhaul specs. some of the numbers just SEEM awfully small to me... In chapter 2, part C: General engine overhaul procedures, I'm looking to find some other specs (as a second opinion kinda thing, maybe Chiltons, or JEEP FACTORY SERVICE MANUAL) on Piston Ring End Gap, Piston to bore clearance, and Piston ring side clearance... the numbers in Haynes are in the .0010 range, but the smallest feeler gauge I have is .0025, and that's thnner than paper. I'm just wondering if they accidentally put an extra zero in there... maybe the numbers are supposed to be in the .010 range instead of .0010? I'm looking for exact spec's.
Thanks
Old 11-10-2004, 09:23 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Technical: Engine Rebuild Question
My brother has built alot of engines, I'm waiting on a response from him on this one.
Old 11-10-2004, 07:39 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
My hayne's manual is saying the same as yours, but I'll look in some other places to see if I can find any more info for ya
Old 11-10-2004, 11:07 PM
JDPascal JDPascal is offline
These clearances are from a 93 cherokee/wrangler factory manual. The 2000 should not have changed in this area but you can decide for your self if you want to use them for your engine.
rings 1&2-
end gap - .010" - .020"
side clearance - .0017" - .0032"
ring 3
end gap - .015" - .055"
side clearance .001" - .010"
Rule of thumb with ring end gaps is .003" - .004" gap per inch of bore diameter. These numbers match up with the specs for an 84 listed in chiltons too.
piston to bore clearance .0013" - .0021"
It also says to replace the pistons if the bore clearance is more than .004"
The piston-bore clearance sounds about right and is just a little looser than the spec for the same engine in 84 as listed a my chiltons (.0009"-.0017").
hope this helps.
JD
Old 11-11-2004, 01:02 AM
My bro's answer goes with all the above:
"End gap is usuall a ratio using the bore size. The 440 was about .012", but since I had Hyperutectic pistons (high silicon content) the top ring had to be about .027" because the piston tops for those types
of pistons run much hotter.
Piston to bore also is variable but is less that end gap, I'd have to look it up. Ring side clearance is the smallest of the measurements if I remember right. "
I'd go with JDPascal on this one, factory manual is likely to be correct.
