I've got a 95 Grand Cherokee Laredo that won't start. I just replaced the battery about 2 months ago. My daughter left the interior light on over night. Battery wouldn't take a charge so I replaced it with a brand new one. Still won't crank. Inside on the voltage gauge it always read around 14 when you turned on the key switch. Now it only reads between 9 & 14. Jeep will crank & run fine when you jump it of. While it's running it reads 14 volts. After turning it off & trying to re-crank it only reads half way between 9 & 14 on the gauge. I also replaced the negative cable & that's not it either. I'm lost on what to do now besides carry jumper cables every where I go so I can get it started.
Re: Grand Cherokee Won't Start
If I were you I would take a volt meter to the alternator (the wiring to the gauge in the car can deteriorate. Take a reading from there. May be time for a new alternator.
the voltage regulator is reading between 9 and 14 volts, when u turn the key to the ON or RUN position? abd it won't crank at all, is that correct.
Re: Re: Grand Cherokee Won't Start
well u can test the altenator by starting the jeep and disconneting the negative battery cable while the jeep is running, if it dies then the alt is bad if it continues running then it is good,
leave the cable off for a minute or so, if it dies at all then it's time for a new altenator. |
also the engine doesn't crank at all when u try to start it, without being jumped?
Well, work your way backwards from the battery. Alternator, then solenoid, ignition etc.
Re: Re: Re: Grand Cherokee Won't Start
well the altenator is prolly not the problem, have u used a Voltmeter and tested the battery when it is off, it should read around 12.6 volts.
Re: Re: Re: Re: Grand Cherokee Won't Start
hummm thats wierd. have u checked the connection to the PCM.
I'll check it in the morning. Already dark outside here. Thanks for the help & if anyone else has an idea please post.
Re: Re: Re: Re: Re: Grand Cherokee Won't Start
I'm hooking from post to post on both batteries. Not using the frame as a ground.
