Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 11-06-2004, 02:52 PM
alphalanos alphalanos is offline
lowering the car.
if i lower my car 1.5" - 2"(with springs) is it possible to keep using my factory shocks or do i have to buy new performance shocks?
96 EJ6. Future home of boosted B18C1.
Old 11-07-2004, 01:01 AM
97integrals's Avatar
97integrals 97integrals is offline
Spend the money now and buy new shocks so you can install them all at once. Otherwise when your stock shocks go dead you will have to do twice the work. You should always install shocks made for lowered cars when you lower your car.
Old 11-07-2004, 09:07 AM
what if i used something like this? from what i understand it has springs and shocks, and its adjustable. i would need a camber kit and alignment job, correct?
here
Old 11-07-2004, 01:49 PM
BullShifter's Avatar
Re: lowering the car.
here
Those would be true coilovers and expect to spend at least $700 for an entry level setup. Yes you should install camber kits and have it aligned. Every time the ride height is changed an alignment is needed. Another thing that should be done is corner weighting, with adjustable springs you can equal all 4 corners by slightly rasising/lowering an opposite corner spring. That MUST be done on scales.
http://www.modacar.com/products/Honda/Civic/MODACOI/
Old 11-07-2004, 10:07 PM
SkyydragRx SkyydragRx is offline
Send a message via AIM to SkyydragRx
my suggestion is don't do it unless you really got the money to blow. I just lowered my 98' accord 2" with eibach sportline springs. I'm running into so many problems. I have to have my rear fenders rolled so that the rear tires won't rub on the fenders. And yes you'll need an alignment and all 4 cambers. The back should just be bars depending on what kind of a car you have. I know mine are just the camber bars, and new ball joints worked out for the front. The front of my car is fine but my rear is totally screwed. So just be careful and really think it through. If you still want to get it lowered go 1.5" not 2".
Old 11-25-2004, 02:54 AM
lotusvale lotusvale is offline
what shocks did you use? i thought eibach sports only lowers to 1.8?
Old 11-25-2004, 09:11 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I put Eibach springs on my stock Si shocks and they were gone in about 6 months. Do it right the first time and same yourself money AND time.
That kit is fine since it comes with matched shocks.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 11-25-2004, 06:15 PM
prototype80's Avatar
prototype80 prototype80 is offline
Send a message via AIM to prototype80 Send a message via MSN to prototype80 Send a message via Yahoo to prototype80
definately change out your stock shocks it took me about a month to blow out my stock shocks i bought the same day i lowered my car(replaced stock shocks with brand new stock shocks) , definately want to go with a good coilover combo, it could really save your car over time
92 civic dx hatch aka the money pit
just another u.s. army paratrooper
