Old 11-06-2004, 12:15 AM
darien99 darien99 is offline
Mods for an '86 305
Hey, if you've been following any of my posts (and who has?) then you'll know I just picked up an '86 Firebird.
I don't really know much about it - I know it has crappy seats that are all ripped up...clearcoat that's coming off all over the car, and that's about it. I think it has the original 305, but I'm not sure. The OD reads 180K, so I'm assuming there's been an engine overhaul in there somewhere. It has an accel distributor, but that's about it for mods.
I had the carb rebuilt but that's it. I'm wondering how to start modding the thing. I don't want to get too crazy and spend thousands of dollars on the thing, because I still have my moneypit Neon project, but I'd like to do a few things to it so I can get a little better than stock HP out of it.
I was thinking of the mods that apply to 4cyl, but I know absolutely nothing about 8cyl or carbed vehicles. Keep in mind that I just moved to Idaho from MI, and have very limited tools and will be working on the car in my girlfriend's parents' driveway.
Here's what I was thinking of doing, for a maximum HP/Cost ratio...
Cold Air Intake - Cone K&N filter run from a 90 degree bend intake tube
Flowmaster 40 Series
Exchange Catalayic Converter with 1ft exhaust pipe
Possibly buying a new intake manifold
Anything else you guys can think of for cheap? Know any good places to buy used performance bolt ons?
Old 11-06-2004, 12:57 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Mods for an '86 305
put a blower on it.
Old 11-06-2004, 06:05 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
wasn't the 305 in 1986 TBI or TPI not carbed right?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-06-2004, 06:22 PM
This may have had a swap, maybe it got a 350! (hopes and hopes)
But I know it DEFINATELY has a carb.
Old 11-06-2004, 06:37 PM
FormulaLT1's Avatar
Fight the powwa!!!
The TBI system looks like its a CARB but it you take off the air filter cover you will see it has TPI sensor by the butterfly.
Old 11-06-2004, 07:05 PM
Thumprkils's Avatar
Thumprkils Thumprkils is offline
Banned
Send a message via Yahoo to Thumprkils
most likely if you look back to the drivers side of the block,between the left head and firewall is a#, if it ends 0110 its a 350, there are other numbers , that are a 350, post them , n theyll reply ,its behind the left head,to the left of the oil pressure, on the back of the block above the toqure converter/flywheel, other little things that hint, mostly older 350s, dipstick on passenger side , i think, most 305 exhaust wont fit a 350, cause the drivers side end up in the way of the dipstick which is as i say on a 305 usally on the drivers side, and on the passenger side the 305 ex mans have the bolt holes are farther apart ,back passengerexhaust port as i discovered with my 82
Old 11-06-2004, 07:09 PM
Thumprkils's Avatar
Banned
to mod it, do these ,intake, carb, cam around 282,
headers,(that cam for 350, as the 305 i not sure what cam would be best). If it is a 350 all the above & a set of 305 heads & flat tops, unless your heads arent better, would probably do you nice, but thats the po boy way
Old 11-06-2004, 08:00 PM
If I remember right, my dipstick is on the passenger side. I'm not sure though.
I'm going out to work on the car tomarrow, I'll take a look at the codes on the block and post them. Thanks for your help so far guys, it's greatly appreicated.
Oh, and I took the carb to a shop to have it rebuilt...if it turns out it's TPI, I'm going to be pissed that someone took me for a ride. I'm pretty sure carbed though, as the car won't start unless you pump the gas a couple times before you turn the key.
Old 11-06-2004, 08:05 PM
FormulaLT1's Avatar
Fight the powwa!!!
TPI doesn't look like a carb, TBI(throttlebody injection) does,,
Old 11-06-2004, 08:06 PM
Sorry, mistyped. Would TBI cause a need for choking the car to start it though?
Genopsyde's Avatar
The President
rather have tpi than carb
Old 11-06-2004, 08:11 PM
Genopsyde's Avatar
The President
mine doesn't
Old 11-06-2004, 08:12 PM
I'll take some pictures tomarrow, as well as checking out the casting numbers and post what I find out for you guys.
Old 11-06-2004, 08:23 PM
FormulaLT1's Avatar
Fight the powwa!!!
most TBI system's have a electronic cold start valve which is also referred to as a choke cause its basically the same thing
Old 11-07-2004, 08:53 AM
Thumprkils's Avatar
Banned
i just like a carb, cause it is simplified, less sensors less junk, easier to maintain, less clutter
