Go Back   Automotive Forums Car Chat > GMC > Syclone | Typhoon
Old 03-13-2004, 07:02 PM
denny jr. denny jr. is offline
Unhappy a sick 93 typhoon
i have a 93 typhoon with a blown motor dose anyone know if a stock 4.3l bottomend is the same or are the pistons and crank different?
thanks for any help you can give me.
denny jr
Old 05-21-2004, 09:52 AM
turbodog's Avatar
turbodog turbodog is offline
As long as the block is 4.3l, no balance shaft and came from the
factory with a roller cam, then it is the same as a SyTy block.
Crankshaft is same as generic 4.3, but bearing caps are NOT. You need to re-use your nodular iron caps from your old engine or convert the new block to 4-bolt (splayed) caps. SyTy pistons are also different, but don't go with GM parts there. Get aftermarket pistons (8.35:1, TRW makes the cheapest I'm aware of) and Eagle rods.
Lots more info at:
www.syty.net
www.sytyauthority.net
www.sytyarchives.com
Rick
'92 GMC Typhoon, '83 Porsche 944
Old 06-16-2004, 04:01 PM
Blazing Rice Blazing Rice is offline
Do you know what failed on the blown motor?
Old 02-01-2005, 01:53 AM
Re: a sick 93 typhoon
sorry i know its been like 6 months since i been here but the typhoon took out #5 piston
