Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 11-05-2004, 08:30 PM
Brandish's Avatar
Brandish Brandish is offline
J-Body blower climate control disease
Well it finally happened... The first three settings on the fan control do nothing, but it will turn on when put to the last setting (max). I've seen/worked on numerous j-bodies with this problem, so I'm wondering if anyone here knows how to fix the problem. Thanks in advance!
Old 11-06-2004, 10:38 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: J-Body blower climate control disease
Yes, you have the dreaded blower resistor syndrome. This is common on GM vehicles and is relatively easy to fix. Go to the dealer and get a blower resistor for your vehicle. Find the fan, usually under the dash, the resistor is located close to the fan. Remove the fan and resistor, replace the resistor, replace fan, disease cured.
Old 11-06-2004, 10:44 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I'm in agreement with GTP, it's your blower resistor that ails your j-car.
Old 11-06-2004, 01:04 PM
Brandish's Avatar
Sweet... Thanks a bunch!
Old 11-09-2004, 10:58 PM
sunfiregirl_96 sunfiregirl_96 is offline
Send a message via MSN to sunfiregirl_96 Send a message via Yahoo to sunfiregirl_96
I think there was a thread a while back about how and where to change the blower resistor, it tells exactly how to change it
but i'm pretty sure that GTP has it down to a science...
i have the same roblem, just too lazy to fix it....
It's NOT how FAST you can drive her, it's all about the driver knowing HOW to drive her FAST!!
'Fire has been put out... She's gone to that big 'ol junkyard in the sky
Old 11-13-2004, 04:25 AM
davydawg davydawg is offline
Send a message via AIM to davydawg Send a message via MSN to davydawg
hehehe same here,, i hate crawling under my dash its a cluster f**k
Old 11-13-2004, 09:19 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
the fan is in the passenger compartment, below the glove compartment, the resistor is on the back of the motor. not to bad to get to really, get a haynes manual and it tells you how to do the check of the resistor, and how to replace it. unless your cheap, then I'll copy and paste my Haynes for you.
