Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-05-2004, 07:57 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Help intake manifold.
I just installed a Trick Flow street intake manifold. After test driving it when I put the car into nuetral I hear a whistling sound. So after tracing the sound I figured it's coming from somewhere around the upper intake. The thing that I dont understand and maybe you can help diagnose the problem is, when I disconnect the idle speed control solenoid the whistling starts up, then when I put it back, it stops. Whats the problem.
Thx for help.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 11-11-2004, 09:19 AM
andrewespo's Avatar
Re: Help intake manifold.
Just for anyone that has a similar problem I called trick flow, they said that if you use a BBK throttle body there is a little hole on the throttle plate which makes a whistling noise when the air is sucked in. I drilled the hole to make it a little bit bigger and the whistling went away.
