Old 11-05-2004, 06:58 PM
bonesr1 bonesr1 is offline
car hard to start
my 99 eclipse gs 2.0 non turbo is very hard to start,it takes about 15 seconds of cranking before it fires up.then idles very rough for about 2 to 3 minutes then runs fine.replaced idler control,throttle position sensor,coolant temp sensor,spark plugs and fuel filter.i have also cleaned the throttle body.any help would be nice.
Old 11-05-2004, 08:20 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: car hard to start
did you align the tps correctly? the only way to be sure is if you have a datalogger.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-06-2004, 12:08 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
where do u live? is it a cold start?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-06-2004, 05:55 AM
they way it looks from the manual the tps could only go on one way.the car runs fine once warm,and fires right up as long as it doesnt sit for more then a few hours.begining to think im losing fuel pressure at the rail.
Old 11-06-2004, 09:03 AM
jsumi jsumi is offline
I recently had a "hard to start" problem with my '92 Turbo.... my mechanic had my ECM rebuilt and it solved the problem.
