Old 11-05-2004, 05:19 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
MY car runs!!! but one problem...
i finally got my 90 tsi AWD running after replacing the head, and putting everything back together. before this all i had experience with was changing spark plugs... i put the timing belt on, along with all new timing parts and got the timing lined up right, finally...i started up my car, ran rough and stalled out. then today after work i discovered i forgot to connect the oxygen sensor and now it runs smooth, but has a bit of high idle...anyways my real problem is the oil pressure gauge reads max. the needle is as far right as it goes. it goes there when the key is switched on and stays there after the car starts. i used a block of wood to support the engine while i had the motor mount off, could this still have damaged the oil pan? would this make a very high pressure reading? let me know what other things i should check first.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 11-05-2004, 05:55 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: MY car runs!!! but one problem...
you probably broke or shorted the wire to your oil pressure sender. usually this causes it to read no pressure if it broke so it probably shorted or you need a new oil pressure sensor. there are two sensors one sends a reading to the ecu the other to the gauge. check your chiltons for testing/replacment
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-05-2004, 07:15 PM
Testiklees
but it reads high pressure. when i start the car it slowly climbs up to the high line and passes it. i can see the wire is still intact
Tim
1990 Talon AWD
PTE SCM5031
Old 11-05-2004, 08:16 PM
hmmmm... thats interesting the way you said it before i thought it just went to full high pressure as soon as the key was on.
-1stGenRocks-
Old 11-06-2004, 12:33 AM
kjewer1 kjewer1 is offline
AF - Advisor
Ohm out the wiring between the tab on the sensor and the other end at the guage, if you can find it. If the wiring checks out, replace the 20 dollar sender. Any damage done to the pan, etc, would show up as low pressure most likely
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-06-2004, 12:39 AM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
while the engine is running take the oil cap off the valve cover, you should see oil being thrown everywhere, and take a look at the bottom of your oil pan to see if its dented in, this happened to me and ruined my oil pickup.
Old 11-06-2004, 12:41 AM
AF - Advisor
But his pressure is high, not low.
Kevin Jewer
Old 11-06-2004, 12:42 AM
AF - Advisor
Re: Re: MY car runs!!! but one problem...
Same thing really. The stock guages have a lot of filtering, takes time for the needle to move.
Kevin Jewer
Old 11-06-2004, 12:05 PM
Testiklees
thanks for the replies, once i find and ohm-meter i'll try it out.
Tim
1990 Talon AWD
PTE SCM5031
