Old 11-05-2004, 03:27 PM
Julioluko Julioluko is offline
how can I tell If i have a bent valve?
HEy guys I just cleaned all of my lifters and i still have this 1 tick! Is a valve bent? how can i tell?
Luke
Old 11-05-2004, 05:01 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: how can I tell If i have a bent valve?
the only way i know for sure to see if a valve is bent is to take the head off, and see if they all match up. are you 100% positive its coming from your motor? i thought my ticking was from my lifters, but it was my evap silinoid
DSM geek
Old 11-05-2004, 06:10 PM
Pretty darn sure, Its comming from middle of intake side right about where the "V" is on "16 valve" 1G valve cover. It varies with the RPMS and i just cant figure it out, where is that Evap solinoid? I have friggin babied this car for the last month I've had it and and this ticking was random and now after i cleaned the lifters its constant, WTF is going on? Could there be carbon or build up on the valve seat? I am just at a loss.
Old 11-05-2004, 06:19 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
no you cant really test it if the head is off... unless you have the machine to do it.
to test it on the car, go to autozone and get a compression tester and run a compression test and post up your numbers... they should all be atleast 145+ on turbo cars and 200+ on non turbo cars
Old 11-06-2004, 12:36 AM
kjewer1 kjewer1 is offline
AF - Advisor
Yes. A very slightly bent valve will still show up as 0 compression most of the time, if not every single time.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-06-2004, 10:18 AM
Oh i really didnt think about that, my compression is 155, so thats great, could it this ticking be carbon bulid up on my valve seats then, I only say this because i have changed out the lifters and rockers and the loud tick is still there at that place. I am wondering if I turn the valve back and forth so it spins on the seat will this remove the carbon (If any) on the seat or since the valve dosent rotate under normal use will this cause me more problems?Im thinking about getting some of that mopar cylinder cleaner and using that to remove all doubt. Any advice guys?
Old 11-06-2004, 10:21 AM
OH and "EclipseRST" Im not trying to venerate you like some saint, but you have helped me alot with my car, thanks buddy.
