Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-05-2004, 03:18 PM
Doubletap Doubletap is offline
Send a message via AIM to Doubletap Send a message via Yahoo to Doubletap
Converting 96+ LS to OBD1
Sorry for anyone who has had to answer this question 8 times but the search just wasn't doing it.
I am about to pick up an OBD I B18C1 for my OBDII LS and I need to know how to switch the car to OBDI, unles someone has a compelling argument for switching the motor to OBD II instead.
Thanks,
DoubleTap
Old 11-05-2004, 07:24 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Converting 96+ LS to OBD1
http://www.boomslang.us/obd2.htm
$74. OBD2 to OBD1 conversion harness.
Old 11-06-2004, 10:55 AM
So with the conversion harness the engine will work properly and allow the freedom to add aftermarket parts without the OBD II kicking in and learning its way around the modifications? Or for that would I need to get an OBD I Ecu for my car. Or something like a Hondata etc.
Thanks,
DoubleTap
Old 11-06-2004, 12:17 PM
CivicSpoon's Avatar
There is no Spoon
Oh sorry, yes you'd need to use the OBD1 ECU as well. And with that you wouldn't have the problems associated with aftermarket parts added to the motor.
Old 11-09-2004, 02:18 AM
JDM00CivicEX JDM00CivicEX is offline
what about passing inspection, i was wondering if your running an OBDI conversion on an OBDII car, will it pass inspection and what will they do to pass inspection? like do they dyno it or hook it up to OBDII computer, and is it legal?
Old 11-09-2004, 07:56 PM
ricergribbs ricergribbs is offline
Send a message via AIM to ricergribbs
i dont think its legal. its technically not legal to drop an older engine into a newer car and thats what hes doing, even if u convert the ecu i think.
