Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-05-2004, 02:12 PM
DOUGSA DOUGSA is offline
sometimes pulls to the right
97 Aurora
My car pulls the right sometimes, but not all the time.
I assume if it was an aligment problem, it would pull all the time.
Can someone point me in the right direction?
Old 11-06-2004, 11:00 AM
rmcilvaine rmcilvaine is offline
Strut Bearing
Hi,
I had the same problem with my 92 Bonneville. It was the upper strut bearing. It is a couple of pieces of plastic that create a bearing surface. You can replace it or do what I did. Jack up the car and squirt a lot of WD-40 in there.
At leaast it worked on the Bonneville untill I replaced the struts and bearings.
Ron
Old 11-06-2004, 02:50 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: sometimes pulls to the right
Does it pull when you drive or when you break? If it is when you break, then one of the break lines probably has some air in the lines or the metering valve is F'd up. If it happens when you drive, it might be the allignment or the struts like the guy above said. The Tire rods might also be bent or maybe your tires are out of balance on that side. Let me know how it goes.
