Old 11-05-2004, 01:53 PM
Skwanny Skwanny is offline
Player Resetting
I bought a car (VW Golf '01) last week that unfortunately did not come with a radio. So the next day I bought myself a generic ("Centrum") style cd/radio player for the car. Hooked it all up without much of a hitch, and everything works fine...
...until the next time I start the car, and the cd/radio player has reset itself and lost all of its settings (pre-programmed stations, bass/treble, etc.).
I've read in another thread that this is due to miswiring - and in that example, the person needed to connect a wire to the chassis (grounding?). However, in my case this doesn't seem to be an option: the connectors are 2 ISO cables, which are already prewired and apparently compatible (since everything worked off the at as soon as I connected them). The only other "connection" is the antenna - and I can find no additional wires!
Incidently, the reset happens not when I turn the car off - but when I remove the key from the ignition (the flashing LED on the player also goes out).
Any ideas?
Old 11-05-2004, 02:38 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Player Resetting
sounds like your permanent power wire is connected to the switched power, so every time you take out the key the cd player behaves as if you unplugged the battery completely and everything resets.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-05-2004, 03:33 PM
Hmmm... makes sense to my novice ears...
Anything I can do to fix this easily, or would I have to rewire the ISO plugs (which sounds wrong, since the whole idea of the ISO's are to save you the hassel I thought!)?
Old 11-05-2004, 03:57 PM
sr20de4evr's Avatar
I'm not really sure what those ISO plugs are exactly....
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-05-2004, 04:19 PM
Talking
Well whaddaya know!!!!!!
In searching the web for a photo/description of an ISO plug, I may have stumbled across the answer to my question
http://www.add-a-cdchanger.co.uk/add..._guide.htm#iso
Funny that I would find a possible answer here, when doing a proper search for the solution on Google didn't help me find a thing
Old 11-06-2004, 12:25 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
wow, that is some wierd stuff, I usuall just go to walmart, and buy that wire harness that plugs to my vehicle, and then solder it to the wire harness off the deck. Usually its easy, black to black, red to red sort of thing. Leave it to volkswagon to switch the constant 12+ yellow wire and the switched 12+ red wire around. Thats wacky, but I'll keep that in mind when installing in future vehicles. Have a nice day, and good luck.
