Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 11-05-2004, 12:36 PM
miragenut miragenut is offline
Send a message via Yahoo to miragenut
Unhappy Stalling
I have a 1993 Mirage ES with a 1.5L i have been having problems with it just stalling out while driving down the road and then not starting again untill a while later (aprox. 30min to 4 hours). I have a gut feeling it is the distributor but when i try to check the flash codes i do not get that code. Also when I try to flash code the ECM i mostly get a continuous flash no rests or anything. I need help in known what is going on with it. If someone else out there has had the same problem please post and let me know wot fixed it or if it is the module or maybe the coil. I have a way to make the coil external if that is the problem then i can fix it. any help would be greatly appreciated.
Old 11-13-2004, 08:32 PM
ock4x4 ock4x4 is offline
Re: Stalling
Hello,
posted 11/13/04
I have the same issue on my 91 mirage. I would like to know if you found a solution yet. I am suspicious of the ECU. If I find out anything I will let you know.
Curtis ([email protected])
Old 11-22-2004, 10:41 AM
mits4g15_1993 mits4g15_1993 is offline
check these out
check this out....
egr not leaking
no vacuum leak in vacuum hoses
map sensor and throtle position sensor
last but not least that your valve clearances are ok
let me know if this works out....
Old 04-12-2005, 04:08 AM
SteVB SteVB is offline
i know this is an old post, but i just wanted to chime in & say that those symptoms sure sound just like when my fuel pump was going bad on my dodge stratus. drove me & 4 different mechanics nuts until it went completely out.
it only died at interstate speeds on long trips 3+ hrs. and would start back up as soon as it was towed to a shop, then wouldnt do it again till it was driven for 3 more hours at hwy. speeds.
Old 04-16-2005, 07:24 PM
diymirage diymirage is offline
the only thing i can say is that the constant flash your getting is considerd a code 9 wich means all systems are normal
Old 08-03-2005, 03:46 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Re: Stalling
Bump,:
Have a 92 with the same stalling problem. But it will start back up if it's left sitting for a while. Any one else fix there's?
I make slow Escorts less-slow.
My cardomain
Old 05-06-2007, 03:58 PM
vetter852002 vetter852002 is offline
Thumbs up Re: Stalling
i jus had the same problem.i replaced the ecm..fuel filter and pump checked all the fuses checked ehaust for stopped up converter finally replaced the distributor fixed the problem..it was a coil problem..the plugs were firing but the coil wasnt puttin out enough juice to start it an made it stall..i replaced the coil with a junk yard distributor with coil cap and everything in it for 35.00$ my car stalled up untill the last time when it wouldnt start at all..hope this helps good luck..and i had my codes checked at advance auto parts..no codes came up on that either..but it was the coil..since i put in the new distributor hasnt stalled once an runs great
