Old 11-05-2004, 12:16 PM
pensfan30157 pensfan30157 is offline
Brake indicator light on 95 3000GT
Hello,
Just noticed this morning that my BRAKE indicator light on instrument cluster is remaining on. I checked fluid level and it looked OK, checked to be sure actual brake lights were working (they were). Made sure parking brake was also not on.
I am assuming that light just means brake fluid level is low??
Can anyone confirm this. That light does not monitor brake pad condition does it?
Thanks for any info!
Old 11-05-2004, 12:24 PM
Italian Lunaticz Italian Lunaticz is offline
Send a message via AIM to Italian Lunaticz
Re: Brake indicator light on 95 3000GT
Originally Posted by pensfan30157
Hello,
I think i have the same problem for the past month or two everytime i accelerate from a complete stop my brake light on the dash stays lit up until i let go of the gas. I do have a back left light out but dont think that matters any? Also i thought before that when i used my e brake you had to push in the button to pull it up but now it feels loose. (Have an auto if that helps any too). Might sound kinda confusing any ideas guys? Is it fluid like he was talkin about?
Old 11-05-2004, 05:05 PM
Igovert500's Avatar
blue + red light magnet
Italian...you are definantly low on brake fluid...it lights up when you floor it, becuase the g-force causes the brake fluid to move to the other side of the reseviour and the sensor thinks that you are out of fluid...so just put some more in, check the manual for details.
Pensfan, I think it does monitor the pads...I honestly don't remember off the top of my head...it should say in teh manual though...and I'd go out and check mine if it weren't 25 degrees outside.
Are you getting any squealing from the brakes yet?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-05-2004, 05:40 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
definitely check the brake fluid and fill if low. however, get back to me if this doesn't solve your problem. sometimes the brake light will remain on if your parking brake cable has been stretched, and thus your parking brake will not fully disengage, so the light will remain on. there are several options to fixing this problem, of which i can outline if filling the brake fluid doens't solve your problem.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-05-2004, 06:22 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Thats what happened when my mom ramed my parked car when she got mad, its still like that even though I know it's an easy fix.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-06-2004, 09:59 AM
Technical_Automan Technical_Automan is offline
Banned
I'm not so sure about just topping the fluid off, because unless there is a leak, it's all still in there. That's your first sign that your pads are getting low (more fluid is needed because the piston in the caliper has to be pushed further due to the pads being worn so the level in the resevoir goes low enough to trigger the brake warning light). So check out your brake pads, if it's not that, the e-brake stretching thing wasn't a bad guess, otherwise it could be a short at the brake switch at the pedal (doubt that though). I also have a question about this though, just so I don't have to go out in the cold and search for anything. When I put my ebrake on, the light doesnt come on...is the plug right on the ebrake or where, so i dont have to go searching in this freaking freezing weather!!!
Old 11-06-2004, 05:31 PM
Thourun's Avatar
I just tightned my E brake up and that solved the problem I think.
1995 3000GT VR-4
Old 11-08-2004, 12:04 PM
Thx guys it was the brake fulid. Jus needed to be topped of a little bit and the light went away.
93 Base 3000GT
Injen Intake
Power 1 exhaust tips
Polk audio speakers
Old 11-08-2004, 01:52 PM
Igovert500's Avatar
Still check your brake pads as Technical Automan is completely right...if you catch worn down pads early enough, it will save your rotors.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
