Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-05-2004, 10:46 AM
dan615 dan615 is offline
exterior lights or park lights wont go off
i bought A 96 Aurora its a nice car but the park lights stay on tried the light switch that doesnt work,dont know what to do? the only thing that will turn them off is if i pull the fuses,then if i need to drive it after dark i have to put the fuses back in,someone said they were on a timer if so its not working and if thats the case where is the timer so i can replace it,or check to see if its bad????? any help would be appreciated...Thanks
Old 11-09-2004, 01:14 AM
96aurora 96aurora is offline
Send a message via AIM to 96aurora
Re: exterior lights or park lights wont go off
this is just a guess, it might be the switch at the top of the turn signal lever, sometimes they can get worn out. It looks really hard to get at, but I would call an olds dealer and ask if that's what it could be.
Old 11-09-2004, 07:23 AM
dred98's Avatar
dred98 dred98 is offline
Don't spend any money until you check out this thread.
http://www.automotiveforums.com/vbu...ad.php?t=198519
Dark Red '98 - Autobahn - Airbox Mod - Sunroof - Cool Blues
http://www.howardm.net/dred98/aurora.php
Old 11-09-2004, 10:48 PM
dmorlow dmorlow is offline
I know this looks like a really simple fix and you might already know this, but do you have the twilight sentenial option turned on? The twilight sentenial option is what makes your lights turn on at night. You don't turn the lights on with the switch anymore after that. But, you will notice also, that the rolling switch that turns it on, it turns a lot. If you just put it past the click where the lights go on when it is dark out, the lights will turn off when you turn the car off. But if that roller is turned all the way to where it stops, when you turn your car off, the lights will stay on for almost 5 minutes. But they will turn off automatically. It's actually a nice feature. Then if you need to walk inside and it is dark out, you can have your headlights pointing to wherever you are walking and they stay on so you can see your way. I can almost bet that is the problem and that isn't a problem at all. You just didn't know that it was a feature in the car. It kind of baffled me the first time I drove the car. I thought I was driving around without my lights on the first time I drove my car at night. I had to get out and look to see my lights were on (it wasn't completely dark out yet that day). And time of experimenting, I figured out the twilight sentenial thing. But there's nothing wrong with your car.
