Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-05-2004, 10:18 AM
kdi kdi is offline
Unhappy 2001 ram 1500 transmission not shifting
I have a 2001 ram 1500 with a 5.2L engine. The truck has 84000 miles on it. Recently the transmission quit shifting into 1st or 2nd gear on take off unless I manully shifted into 1st gear, however sometimes even manually shifting into 1st gear it will only shift down to 2nd. Drive, overdrive and reverse works fine. I have replaced the transmission filter and fluid. The fluid level when checked with the engine hot and transmission in neutral is o.k.. Could this be a valve body problem or will the transmission need a complete overhaul.
Old 11-05-2004, 10:01 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 2001 ram 1500 transmission not shifting
It might be something as simple as a sensor, but an overhaul might be the answer too. Is your check engine light on?
My Mopars
Old 11-08-2004, 12:05 PM
corjliza corjliza is offline
Send a message via Yahoo to corjliza
I recently had a similar problem with the tran not shifting properly and it ended up being the speed output sensor, cost aobut $12 and easy to switch out yourself
Old 11-08-2004, 03:39 PM
kdi kdi is offline
Well today I purchased a code reader which produced code P1756 which translates to governor pressure not equal to target at 15-20 psi. I know that the code came from the tansmission. Any suggestions on how to correct the problem? Yes The check engine light was on.
Old 11-08-2004, 04:31 PM
kb3 kb3 is offline
Question
this is not nesessarilly a reply but another problem. today i had a very simular problem with my '01 ram 1500 4x4. got in and reverse fine, drive fine, then it wouldn't shift into 2nd until aprox 3000-3500 rpm, od fine, down shifts fine. engine light came on. (no code yet). light came on about 6 monthes ago changed fluid and filter then reset light no problems since until today. checked fluid hot and it is fine. 95k miles and i don't tow with it but previous owner did. any help would be greatly appreciated.
Old 11-09-2004, 02:24 AM
hundahunta hundahunta is offline
this is a common failure... we have seen these governer pressure sensors fail often. most codes are governer pressure sensor volts too high or low, governer pressure sensor not equal to target.. Most of the time we replace the governer pressure sensor and soleniod.. I would recommend you to fix this problem if not you will end up burning the clutches in the trans... The trans pan needs to be removed....the sensor is bolted to the valve body and is located on the pass front side of the valve body
Old 11-10-2004, 07:17 PM
kb3 kb3 is offline
thanks hunda. here is another twist to the plot. today went went to the parts store to get another filter to change it out, and everything was fine. no shift problems everything seemed fine. would the govener sensor fail intermittantly like that?? one day it works next it doesn't??
Old 11-10-2004, 10:16 PM
not really, unless you have a intermittent connection problem, or a leaking valve body seal..
Old 11-11-2004, 08:11 AM
kdi kdi is offline
Thanks for the info. I'll give it a try.
Old 09-15-2005, 09:56 AM
farmerjones53 farmerjones53 is offline
Re: Re: 2001 ram 1500 transmission not shifting
I have 2001 dodge ram . The codes kept saying governer pressure problems. A local tranny shop replaced both units twice. Still the code, and as soon as engine started the the code was set again.
Finialy i drove it several days in limp mode. Then rechecked codes, now there was also an. oxygen senser code. so I unpluged both oxygen sensers and reset codes and started the engine and to my surprize no tranny codes . I inspected the oxygen sensers and found the rear one had a little damage {maybe a rock hit it} it look minor however i replaced it . Cleared all codes , now every thing works fine.
Maybe this will help some one .
Old 09-15-2005, 08:16 PM
motoxno53 motoxno53 is offline
Send a message via Yahoo to motoxno53
Ahhhh Not Shifting
My truck is doing the same thing and yep I got a p1757 code damn it...
Chris
Old 10-13-2008, 10:55 PM
hardluck30 hardluck30 is offline
Question Re: 2001 ram 1500 transmission not shifting
I have been having a very similar problem with my 2000 1500. Sometimes the tranny will start out in low gear but never come out of 1st. When i re-start the engine a few times it will feel like it is slipping and I have to manually pull it into 1st, but after I get going it shifts just fine. This is obviously an electrical problem. The scanner just says "eletrical short" or "internal failure" but other than this problem the tranny is VERY strong. Can ANYONE give me some advice?? I'm not a transmission mechanic, I'm used to dealing with EVERYTHING else. I replaced the transmission about a year and a half ago with one from a salvage yard that only had 20k miles.
Old 01-12-2009, 08:56 PM
recsdc recsdc is offline
Question I have a 98 1500 5.2 4x4, same tranny problem shifts sometimes at 3000-4000 rpm, sometimes fine, ran code check came back with 0720 Output speed sensor, my Chiltons doesn't show where that is on the truck. I bought a new one can someone help as to its location? Thanks
Old 01-12-2009, 09:01 PM
my 98 1500, 5.2 4x4, shifts sometimes at 3000-4000 rpm, My code was 0720 output speed sensor I bought a new one but my Chiltons doesnt show where it goes. Can someone help? Thanks
Old 07-31-2009, 10:16 PM
2000ram37 2000ram37 is offline
Crawl under the driver side toward the front of your tranny...it's facing almost straight down...you cant miss it. 1" deepwell socket works best. You will lose a small amount of fluid.
