Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-05-2004, 10:18 AM
riff22 riff22 is offline
posible fuel cut??
I have a 95 talon tsi, 2.5 downpipe, all exhaust stuff ported out, stock t25, and bov venting to atmospher. I turned my boost up to 14psi. i think im hitting fuel cut, at like 4 grand it kinda hessitates, but then 4.5 to 7 its fine. is this fuel cut? should i have fuel cut at 14 psi?
thanks
~tyler~
Old 11-05-2004, 10:36 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: posible fuel cut??
i wouldnt think so that turbo is suposed to do 14 stock, my friend had a 95 talon he didnt have a fuel cut problem until he went into the 22+ boost level so you shouldnt have it now
Old 11-05-2004, 04:33 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Fuel cut isn't just a hesitation, it's like hitting a brick wall. I had never felt it before, and when a friend of mine told me he was hitting it (cold night), I wanted to ride so I could actually feel it. Needless to say, it's like hitting a fucking brick wall, not a simple hesitation.
Your problem is mostly likely either A.) Spark plugs B.) Plug wires C.) Boost leak. I'm thinking it's A or B, so check those first.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 11-05-2004, 08:29 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Re: posible fuel cut??
I'm not sure the T25 can flow enough to hit fuel cut, even on the stock fuel system. Like Matt says, check your ignition wires.
1996 Eagle Talon
Old 11-05-2004, 11:00 PM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
Re: Re: Re: posible fuel cut??
mine hits fuel cut on 15psi on cold night with a 5th inj on the intake, the guy that i got the car from didnt have the money to spend on a fuel upgrade so he got a 250cc inj and had a shop put it in on the intake, and it kicks in over 12psi. So now when i do my fuel upgrade here soon i have to get a new intake manifold and a new fuel line to take out the T that they put in to run fuel to it.
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 11-06-2004, 03:36 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
In my experience, you definately can hit fuel cut with a T25, and you can have a stuttering related to fuel cut/boost settings. Since air is measured per revolution, at low RPM, the T25 can still boost high enough to hit fuel cut. Also, at one MBC setting, my car wouldn't hit fuel cut, but stutter like it was on the verge of doing it.
Do an intake pressure test, and turn down the boost and see if it's still there. Stuttering can be many things, and 14psi by the numbers should not be a problem.
Old 11-06-2004, 04:43 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
shit when i had the t-25 on my GST i did everything i could to max it out and i never hit fuel cut, at about 24-26psi between 3500-4200rpms then it would drop off to 17-18 as the rpms got higher. that is with no hose connected to the wastegate actuater (sp?) {sorry its late and i cant think!} but it sure was a fun ride.
Old 11-06-2004, 09:31 AM
well it didnt do it before i put the boost controller on it and turned it up. it doesnt feel like im hitting a brick wall, just a hesitation. as for the plugs and wires there brand new and ran fine with them till i turned the boost up. im starting to think maybe bad pump or fuel filter??
Old 11-07-2004, 09:12 PM
Those would be good to check too. Also, what are you spark plugs gapped at? If you just bought them and installed them without checking the gap, then most likely the gap is too big. For your mods, .028 would be good.
95 GSX
Old 11-08-2004, 01:50 PM
GSTRacerNVUS GSTRacerNVUS is offline
This might help...
http://www.dsm.org/menu.epl?item=289
Ok, nevermind... Neither one of the links work. It would be nice if they did.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
