Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-22-2002, 02:36 PM
TerryJoe's Avatar
TerryJoe TerryJoe is offline
Send a message via Yahoo to TerryJoe
need info about a drop
ok i just bought me a 94 accord and i am about to order some Extreme RX Series 3.25 Front/3.00 Rear springs from sprint.
what i need to know is am i gonna need anything else like stiffer struts
camber kit ect.. to keep ride quality? all help is welcomed
thx
terry thornburgh
Old 02-22-2002, 03:40 PM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
If your dropping it that much, you will definately need new struts, or else ride quality will be very poor. You'll also need a camber kit, or else you'll go through a new set of tires every couple of months. As far as struts go, I think you should go with Koni Yellows. They are probably one of the best (if not the best) one to go with. Good luck.
AF Nordic Crew #3
Old 02-23-2002, 01:54 AM
r1ch_b r1ch_b is offline
Send a message via ICQ to r1ch_b
well, I use extreme RX and I did use to have stock shocks. I don't drive too much so I didn't wore out those shocks. I changed to Koni Yellows for better handling only
Camber kits........not yet. Like I said, I don;t drive too much so I don't waste tire threads a lot. I only did alignment.
Plus, I use 18x7.5 wheels, so I'm afraid that using camber kits will just cause the wheel to rub the fender most of the times.
Good luck with yours....and let us know how you finally do it
:sun:
94 Accord with a few mods here and there...
http://www.imagestation.com/album/?id=4291981901
Old 02-26-2002, 12:51 AM
TerryJoe's Avatar
thx
ok sorry it took so long to reply i havent been home for a while but anyways i just got my springs in but i figured i better wait untill i get the struts and the camber kit and just do the instal all at once
your info helped out a lot
thx
terry thornburgh
