| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Can overdrive be utilized in any way during a race?
Hey guys, it's me again... lol I just wanted to know if you can use overdrive in any way during a race. Please don't hurt me if this is one of those really retarded questions that I just don't know about...
lol
'96 Green Eclipse GS-T Stock for now... |
Re: Can overdrive be utilized in any way during a race?
There's a lot of variables for your question. AT or MT?
IMO... I wouldn't go into overdrive unless I was highway racing @ higher speeds... Even then, I'd still want to downshift.
97 Eclipse GST MT ![]() Race Every Day Like It Will Be Your Last. My one insignificant mod: Dump Tube - CUT |
the O/D button on your auto trans does not turn Overdrive on, it turns it off, overdrive is just your 4th gear.
its not a bad idea to turn it off, but it probably wouldn't be shifting into 4th anyway.
Dr. Disque - Current cars: 2008 BMW 135i M-Sport 2011 Mazda2 Touring Past cars: 2007 Mazda 6S 5-door MT 1999 Ford Taurus SE Duratec |
if your throttle is wide open it wont shift into overdrive. it only shifts into overdrive when its just cruising at part throttle. as soon as you punch the gas it downshifts into 3rd
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
OD doesnt matter if you have it on or off. It gives you no sort of extra HP. Its just your fourth gear. If you dont have it on it wont shift to 4th. And if you drive with it off Youll juss lose gas milage(sp?)
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
I heard that the AT DSM trannys shift at a lower RPM when the OD is activated. HAving never owned a AT DSM though I cant verify this. EIther way, with the gear ratio being taller I cant see any need for that gear when racing unless you are at high speed. IF you arent at redline in third, you dont need 4th
OF course on the T25 though you tend to be out of steam around 6500 based on my personal experience, but you get the idea.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
o/d is your fourth gear, that's it. Your "money" gear is an automatic would be 3rd, because of the 1:1 gear ratio.
over drive is for going up steep or long hills
actually, you turn your overdrive OFF on steep hills
Yes. You can stay in OD if there is enough torque. My turbo diesel (450 ft-lbs) for example will pull 13,000 gross up a nice hill in OD. But if the motor is lugging turn it off/downshift.
Yeah, I kinda figured it was useless when I raced...
