| Let's get Technical! Discussion for hardcore in-depth motor heads! |
Ok,
So ii have looked up and down this whole forum but have not found any items to the liking of the following post. I will ask MODS to either keep this thread here, make it a sticky, or put it in a rapidly accessible place for all NOOBS. I am still a noob, but ma oh man would i have liked for someone to answer these questions for me at some point, i had to do much searching outside this forum to find out what some of tehse were, others were answered by members, but like i said, there was no specific thread assigned to do this job. i know some of the q's have been answered in other threads but it is always nice to keep them all together. First of all: What is a "head"?what does it do? Where is the "intake manifold"?what does it do? What are RPM's?what does it do? What is "idle"?what does it do? What is the difference between VTEC and non VTEC? DOCH and SOCH? What are . CAI, short RAM and other typed of intakes?what does it do? What are the main components of the engine? What is JDM? What are "turbos"?what does it do? "Superchargers"?what does it do? "slicks"?what does it do? "headers"?what does it do? and if you guys want to add any other q's that would be great. Thanks!!!!
i'll burn you at the track...........eventually |
First off it's DOHC and SOHC; Dual Overhead Cam (meaning 2 cams) and Single Overhead Cam (meaning 1 cam).And for Honda/Acuras (for the most part) it's header (as in 1) and not headers implying there are more than 1. |
JDM = japanese domestic market ie the shit we dont get here
RPM = revalotions per minute ie home many times you pistons go up or down in a minute Idle= the rpms at a stand still should be around 500 -800 slicks= tires with great amount or grip good for drag racing
Goodbye civic Hello turbo outback goodbye outback Hello WRX |
Re: All The Basics!!!!!
) pretty much has "gates" ; valves, that open and close, also directs air from the manifold via ports to the combustion chamber.intake manifold=directs air from the air filter through individual runners into the ports that are located in the head. also controls amount of air is allowed to the engine via throttle body. RPM=revolutions per minute; how many times the crankshaft turns in 1 minute. idle=rpm or state where the engine is running but your foot is off the throttle. VTEC=2 cam profiles(cams are what control when the valves open and close in the head), non-VTEC= single cam profile. DOHC and SOHC; explained above. CAI=Cold Air Intake; air filter is outside of the engine bay where it can suck in cold air, Short Ram: an intake system that consist of a short air tube. both CAI and Short Ram are connected to the intake manifold. all they do is direct air into the intake manifold. main components: Block, Head, Valvetrain, Crank, Piston, Rod(might be more, if any knows just add on) JDM=explained above turbochargers: force air into the engine via two centrifugal "pumps"; the compressor and the turbine. turbocharges use exaust gas to turn the turbine, which in turn turns the compressor and forces air into the intake manifold. supercharger; same concept of the turbo except they run off the engine(via pulley). there are two types; centrifugal and roots. roots is like the turbocharger with out the turbine, roots is like two "scrolls" that force air, works like an oil pump. slicks=tires that are "bald" in order to create the largest contact patch on the road surface. used in racing. header=directs exhaust gases away from the engine; directs gasses into exhaust system. |
You see, now anyone can come here, look at thepost and see most of teh basics they need to knwo in order to be able to wok on heir beautiful engines. Cool, thnX
no prob it should have gotten out there sooner
That's true! ha ha,
if we could only make a single thread... or forum... kinda like a diccionary, wher people could go and find pretty much any term related to their car. that would be awesome. hard, but awesome! just a thought
www.howstuffworks.com its all there
www.google.com its all there
D16Y7/D16Y8 mini-me swap turbo coming this summer |
I hate having to repeat myself.
Read it, learn it, live it guys. "Here's the scoop on learning about engines and cars in general. GO TO SCHOOL DUDE. The internet is no replacement or even viable alternative to a formal automotive education." |
