Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-04-2004, 05:34 PM
treeclimber treeclimber is offline
2004 Hemi Ram 1500 Horn Problem
My horn must be posessed. I drive my truck all day, no problems. When I park it in the evening about 2-3 hours later the horn starts blowing. It stops when I get my keys and run out into the driveway and unlock it and press the button on the steering wheel. The only way I can keep it from happening is to take the fuse out. I'm worried it will do it some time when I'm not around to hear it. Any ideas or should I take it in for service (It only has 6000 miles on it). Thanks for any help.
Old 11-04-2004, 08:06 PM
PigPen5150 PigPen5150 is offline
Send a message via AIM to PigPen5150
Re: 2004 Hemi Ram 1500 Horn Problem
Take it to the dealer and let them mess with it. You'll probably have to leave it for a while so they can duplicate it. Or maybe they can find something wrong using the scan tool.
Old 11-05-2004, 09:42 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
A guy in the Durango forums had this same problem. Turns out he had ghosts.
My Mopars
Old 11-06-2004, 12:47 PM
When I worked at a Chrysler dealer, we had quite a few problems with body computers and "ghosts". Along with the infamous ghost wiping on the Caravans and such
Old 01-10-2005, 10:34 AM
HemiLover HemiLover is offline
Question Horn Sticks
I have a 2004 1500 SLT Quad Hemi with about 1400 miles when the first horn event occurred. I walked out to the parking lot after leaving work to find the horn stuck on. Not beeping, just a continuous beeeeeep. The only thing that would turn the horn off was to remove the fuse. After about 15 minutes, I decided to put the fuse back and all seemed back to normal. The truck sat outside after arriving home for about 2 hours and then the horn started blaring again...and again I removed the fuse. The dealer said it had something to do with ?Ghosts? and decided the clock spring needed replacing. Replacement of the clock spring did not fix the problem. So....they want to run an electrical diagnostics on the truck and need it back for a day. Any suggestions as to the cause and fix for this problem?
Old 01-26-2005, 09:27 AM
Ok, here was the cause. The horn/airbag pad switch was defective from the manufacture. It was replaced under warranty.
