Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-04-2004, 05:04 PM
93burb's Avatar
93burb 93burb is offline
Heater problems
Seems like everything is there...the hoses are connected, the blower is blowing, and the settings seem to work. But it doesn't heat up! What am I forgetting to check? I can move the settings to hot and I see the arrow move over to H (my display is digital), but the air is not hot, not even warm! Help, winter is coming and I really need a heater.
Old 11-05-2004, 11:28 PM
Boomyal Boomyal is offline
Re: Heater problems
No expert here, but to eliminate the electronics I would find the heater hoses and make sure they are hot, both into the heater core and out of it. If there is a significant difference in temp. I would speculate that you have a plugged heater core. If not, I'd be visiting the junk yard.
I have a '94 and I shudder at the thought of all the electronic controls.
Old 11-22-2004, 03:47 PM
bcleeper bcleeper is offline
Re: Heater problems
This may seem obvious but to a novice like me it was new. I let the coolant level get low in my van one time and it wouldn't heat up when it was not moving. Check you coolant levels and quality. I know also know that coolant doesn't burn off so if it is low you have a leak somewhere so you will want to check for that too.
