Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-04-2004, 04:53 PM
MDT1955 MDT1955 is offline
Send a message via AIM to MDT1955
Question 1998 Jimmy heat blending door
Been suddenly having problems with the heater alternately blowing hot and cool air evey 10-15 seconds. Doesn't matter if AIR button is lit or just running heat or vent. Blending door is slowing moving back and forth causing a sqweeking, creeking noise. Computer Climate Controlled. Is it a bad Temp. switch or in the computer or ??? Please check my other post 2 pages back for other problems and symptoms that MAY or could be related......ANY replys or HELP will be greatly appreciated. Thanks, Mike
Old 11-05-2004, 07:45 AM
BobcatAZ's Avatar
BobcatAZ BobcatAZ is offline
Question ???????
Don' know but I've got a '98 and I'm interested in following your fix. My guess, considering your other problems, would be to look for bad electrical connections. I would find and clean all ground connections of any electrical harnesses. I would also pull the dash out and check for clean connections at the harness to gauge cluster and other controls. Also, look for a break in the foils of the gauge package circuit. Keep us posted and good luck.
Bobcat.
America, Love IT or Leave It !
Search & Rescue www.rescue.az.org
Old 11-08-2004, 12:10 PM
smonaldo smonaldo is offline
I just posted a new thread regarding a heating problem, but my problem is that it seems as though it is always the same amonut of hot air, and I can't shut it down or increase it. Watch for a possible answer to my thread
Old 11-08-2004, 10:49 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1998 Jimmy heat blending door
install a new rad cap and make sure you don't have any vacuum leaks associated with the door.
1995 Factory Blazer Service Manual for sale, PM if interested.
