Old 11-04-2004, 04:26 PM
rebel112r rebel112r is offline
Gap ck
97 Grand Prix w/3.1 v6. What is the gap for the plugs, have original ac 41-940 plugs.. Also any tricks for getting to the 3 cyls nearest the firewall..With this boards help got my heater woes fixed.. Thanks in advance and again for heater advice..
Old 11-04-2004, 05:10 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Gap ck
.060 is the gap for those plugs.
Old 11-05-2004, 10:02 AM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
Re: Gap ck
you might try removing the engine brackets as suggested here:
http://www.zzperformance.com/zzp/fre...nebrackets.htm
every1 here says you learn new curses when you change em.
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 11-05-2004, 10:15 AM
Re: Gap ck
Just what I need, some new curse words!! Will tackle the job later today, thanks for the reply.
Old 11-05-2004, 10:21 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Gap ck
unless they are obviously screwed up, don't re-gap the plugs. You can do more damage misaligning the electrodes while re-gapping than correcting a couple thousandths off on the gap would help. As far as the rear plugs, put a jack under the trans pan (with a board to spread the load) and take out the two "dog bone" upper mounts. Jack teh trans up to tilt the engine forward, and the plugs are easy to get to.
Old 11-05-2004, 03:12 PM
Odin Odin is offline
Re: Gap ck
i find that if you remove the dog bones and roll the car a lil foward and set the ebrake you can get to them easy as PIE
Old 11-05-2004, 03:24 PM
Re: Gap ck
Job done..Removed 2 bolts and 2 nuts from coil bracket and moved coils uo and out of way and was able to get at them fairly easily, did cuss a few times, pretty normal, thanks again..
