Old 11-04-2004, 04:09 PM
BLAZERBOY69 BLAZERBOY69 is offline
Angry Turn Light Conundrum.
Got A Problem With My Passenger Side Blinker.
The Driver Side Blinks Fine At All Points (front, Rear, And Console) Passenger Side Does Not Turn On At All. I Can Hear The Switch Inside The Column Clicking Like Normal When I Turn The Wheel, And It Releases When I Recover The Wheel, But The Lights Won't Blink. I Checked And Replaced All Lights, Just In Case, To No Avail. Any Ideas For This Perplexing Quandry Would Be Most Appreciated.
Old 11-04-2004, 04:51 PM
busa_4 busa_4 is offline
check the blinker relay.
Old 11-04-2004, 05:15 PM
Re: Turn Light Conundrum.
Where Would The Blinker Relay Be Located? I Can't Seem To Find It In My Haynes.
Old 11-04-2004, 07:24 PM
my 1998 s10 is behind the glove box. check there or under the drivers dash. your haynes manual should have a wiring diagram in the back section for the light circuit. it should tell you in there.
Old 11-04-2004, 09:28 PM
Mikado14 Mikado14 is offline
Not knowing the year of your vehicle you could have a relay for the turn and one for the 4 way. However, I doubt that that is your problem. The first thing to check is the switch in the column. If the left is working and the right isn't, the problem will start there for both sides use the same flasher for turn.
Old 11-06-2004, 03:28 AM
Mindjob360 Mindjob360 is offline
there was a recall on that their is a problem with the relay soldering shorting out
Old 11-09-2004, 03:20 PM
I Have A 1984 S10 Blazer..... So Where Would The Relay Be?
Old 11-10-2004, 10:54 AM
Re: Re: Turn Light Conundrum.
There should only be one flasher for the turn signals. If it functions on one side but not the other, how can it be the flasher? Wouldn't a shorted connection affect both sides?
Old 12-01-2004, 05:33 PM
tomcat_one tomcat_one is offline
Re: Re: Re: Turn Light Conundrum.
Once you figure it out, let me know, I have a 98 blazer and the darn thing woun't shut off most of the time, works fine in the turns! lol, no realy, lights work normaly, just the clicker woun't shut off, suspect the colum conection. If someone has a copy of the recall notice, please post or forward
thanks!
