Old 11-04-2004, 02:52 PM
boogman42 boogman42 is offline
s-10 fuel pumps
i have a friend with a 95 4-cyl that won't start cause fuel pump never stops.have heard this story before with s-10 6cyl.he put new pump,even ecm,well computer if that the same?(under glove box).been chasing wires and sensors to see if bad connections,no luck.any suggestions?
Old 11-04-2004, 03:53 PM
busa_4 busa_4 is offline
Re: s-10 fuel pumps
the fuel pump doesnt shut off? or the fuel pump doesnt turn on? did you check the fuel pump relay?
Old 11-04-2004, 10:25 PM
not_mine's Avatar
not_mine not_mine is offline
Re: s-10 fuel pumps
check the PSI?
Old 11-07-2004, 11:12 AM
9 oz" productions 9 oz" productions is offline
Re: s-10 fuel pumps
it has to be the relay because its getting power to turn on so the fuse isnt on and thats the next thing inline to have any affect on the voltage.
Old 11-11-2004, 07:08 AM
rrzimmer rrzimmer is offline
Re: Re: s-10 fuel pumps
I have scanner with repair track and this problem was in it. They said it was your oil pressure switch for your backup fuel system. It is located behind your distributor. They said what happen is it shorts out. This pressure switch is not the same one for you instrument gage. Good luck.
Old 11-11-2004, 05:57 PM
not_mine's Avatar
Re: Re: Re: s-10 fuel pumps
Good one!
Old 11-12-2004, 09:33 AM
Re: Re: Re: Re: s-10 fuel pumps
Originally Posted by not_mine
Good one!
I just looked up the wire diagram for the fuel system and the back up fuel system which is the oil pressure switch has its own voltage path to the fuel pump. Thats why the fuel pump cont. to run after you turn the key off. This repair track I use has been right everytime I had problems. This oil pressure switch shouldn't cost but maybe $40.00 tops from the dealer. Who knows maybe you can get the dealer to replace it for free.
Old 01-16-2005, 11:47 AM
cc0701 cc0701 is offline
s10 fuel pump
We are having a problem with the fuel pump also. We installed a new one but there is still not power going to it. could someone send me a fuel pump diagram?
