Old 11-04-2004, 02:21 PM
dingpoo dingpoo is offline
Send a message via MSN to dingpoo
car audio
when hooking up a new system, where does the REM wire going from the back of the Amplifier to the cd player go? also, i am having problems with the memory of the cd player, so if anyone knows the wires to hook together for that...thanks.
Old 11-04-2004, 07:34 PM
Re: car audio
okay, i got the memory working. but i still havent figured out the REM, any suggestions?
Old 11-04-2004, 08:42 PM
PigPen5150 PigPen5150 is offline
Send a message via AIM to PigPen5150
Re: car audio
Is it the stock system or aftermarket?
Old 11-05-2004, 12:06 AM
Re: car audio
aftermarket
Old 11-05-2004, 10:08 AM
giltyler giltyler is offline
Re: car audio
That is possibly a power wire for a disk changer
Old 11-06-2004, 01:41 PM
Re: car audio
If you need a wire to switch the amp on, then it's probably a blue one off of the back of your head unit.
Old 11-06-2004, 04:29 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: car audio
The REM wire goes to the Power antenna wire comming off the back of the stereo I believe. This is the Remote wire right?
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 11-06-2004, 11:57 PM
72 rs's Avatar
72 rs 72 rs is offline
Re: car audio
the remote wire is designed to turn a amp on when the head unit it turned on.............if a unit has a power ant. hook up ( raises and lowers power ant. when radio is off or on ) it will be labled so.
Old 11-07-2004, 04:39 PM
Re: car audio
k, thanks guys, its fixed now. but now my sub keeps going from hi, to low, it even turns off sometimes. i dont know if it is just a loose wire or not. any suggestions?
Old 11-08-2004, 10:22 AM
Pewter'01SS's Avatar
Pewter'01SS Pewter'01SS is offline
Define "hi to low". If you mean volume, it could be a loose wire. If the RCA's are loose or crimped, they can play hell with the speakers. Check the outputs on the back of the head unit to see if anything is loose or crimped up against something else under the dash. Also, are you sure your amp isn't overheating? When my amp is cold, it sounds great, the longer the subs are hitting, the quieter it gets until the amps safety system turns it off.
R.I.P. Andy...It was an honor to have known you.
'01 Camaro SS - SLP Short Throw Shifter, Granatelli Air Lid, blue neon underbody kit
'92 Chevy 1/2 ton 4X4 - 350 w/ 190,000 miles and in desperate need of a rebuild.
'86 Chevy S10 - 350 w/ 400 Turbo trans, B&M Pro-Ratchet, 4.56 Posi, 350 is gone and slowly being replaced.
Old 11-08-2004, 03:27 PM
Re: car audio
k, i'll check out the wires again, i must have missed something. but yea, i do mean the volume. i dont think its the amp overheating just because i live in alaska so my amp is usually pretty cold most of the time. and it wont keep getting quieter and quieter it will vary most of the time.
Old 11-11-2004, 02:36 PM
Re: car audio
could it be the fact that, the wire going from my amp to my battery is a really small gauge?
Old 11-11-2004, 11:31 PM
How small a gauge is it? How many watts is the amp rated at?
I know I'm funny, too bad looks aren't everything.
Old 11-12-2004, 01:42 AM
Re: car audio
ita a pretty small wire, like, i regular speaker wire and the amp is 1000 watts
Old 11-12-2004, 04:14 PM
broughy84's Avatar
Re: car audio
WAY TO SMALL, DON'T BURN YOUR CAR UP!!
You should have at least a 6 gauge wire and a fuse in line with the battery. You will over heat that wire and catch it on fire.
Matthew Brough
