Old 11-04-2004, 01:04 PM
lckycharm713's Avatar
lckycharm713 lckycharm713 is offline
headlight are dim
hey guys, does anyone have a problem with their headlights not being bright. mine has always been dim. high beams seem like low beams. not that bright and dont shine high and wide, whats the deal. can i do something to make that better. any adjustments? or do i need new bulbs. if so, what kind?
2000 Mustang - just a V6 with lots of good looks
1974 Camaro - 350 4bolt main .30 over, turbo 350 trans w/ shift kit.
1999 F-150 Lariat 4x4 5.4L
"Only babies suck bottles (NOS)"
Old 11-04-2004, 01:46 PM
bigbob bigbob is offline
Re: headlight are dim
i have the same problem they dont light up the road 3 feet in front of you. not sure what it is but any help here would be cool.
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 11-04-2004, 07:48 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
how dirty are your lenses?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 11-05-2004, 10:02 PM
rerun rerun is offline
my 1992 Grand Marquis has the exact same problem, when i'm ideling they even go "yellowish". i'm thinking maybe the lenes need to be wet sanded and polished.. but i would also like to have some info on this problem.
Old 11-06-2004, 07:02 PM
restomod's Avatar
restomod restomod is offline
If it gets brighter when you rev the engine then I think the Alternator isn't doing its job. Maybe old or not large enough.
Have you tried halgon lights?
Old 12-01-2004, 09:41 AM
mustangsally40 mustangsally40 is offline
Smile Leadlights are dim
I had a similar problem on my mustang and my minivan. First I used the white rubbing compound from AZ and the light polish in a small tube from AZ (1.00) Made a big difference. My lights were also yellow. Good luck
Old 01-03-2005, 11:48 PM
whitestanggt whitestanggt is offline
I put a set of euro-clear cobra lights on my 96 GT with silver star bulbs.....much brighter. I also seen an add on a website that offered "heavy-duty" wiring harness and relay for the headlights of late model mustangs since this seems to be a redundant problem
Old 01-04-2005, 06:58 AM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Dim Headlights
Try the Sylvania SilverStar bulbs (9007). I just installed a set of them on my 1996 GT, and it made a BIG difference....
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 01-04-2005, 09:38 AM
gmartinez gmartinez is offline
I have the same problem on my 86 Lx.
rebuilding my 86 LX??
Old 01-04-2005, 10:18 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
try fluerescent lights
